Switching conditions on/off with Step or Rectangle
Hi !
I'm using Comsol Version 4.0a
I have a heat source for a domain that I want to switch on for some milliseconds and then switch off.
In Parameters I have defined a constant called Heat and given it the correct value and denomination (W/m^3)
When using the step function I get the temperature of the domain to the correct temperature, but ot turned off the heat.
I defined the heat source as step(t)*Heat
Tried to use the Rectangle function, but now the temperature of the particle will not rise, using the following equation as heat source Rect(t)*Heat
Also I get the yellow text in the heat source field with the "Unexpected unit of input" even though this should be correct.
Any tips would be greatly appreciated
Nils Eivind
3 Replies Last Post Sep 18, 2016, 6:06 a.m. EDT
Posted: 1 decade ago Nov 9, 2010, 8:45 a.m. EST
"Case closed"
Got it solved it by "thinking opposite" - turn off heat source instead off turning it on and then off again.
"Case closed" Got it solved it by "thinking opposite" - turn off heat source instead off turning it on and then off again.
Magnus Ringh COMSOL Employee
Posted: 1 decade ago Nov 9, 2010, 9:39 a.m. EST
Great!
Just a note about the unit warning: Functions expect dimensionless inputs and outputs, so you can eliminate the orange color and the "unexpected unit of input" warning by making t dimensionless using [1/s]:
Rect(t[1/s])*Heat
Magnus Ringh, COMSOL
Great! Just a note about the unit warning: Functions expect dimensionless inputs and outputs, so you can eliminate the orange color and the "unexpected unit of input" warning by making t dimensionless using [1/s]: Rect(t[1/s])*Heat Magnus Ringh, COMSOL
Posted: 9 years ago Sep 18, 2016, 6:06 a.m. EDT
using the version 5.2, in the variable expression i try to use sinh(phi) or cosh(phi) and give them a name , the unit of (phi) is the volt wich is the variable of electrostatic module, but the color is orange and show ''unexpected unit of input'' so i can't use it in boundary condition ad i can't solve my problem
Appreciate much for your help!!
Hi using the version 5.2, in the variable expression i try to use sinh(phi) or cosh(phi) and give them a name , the unit of (phi) is the volt wich is the variable of electrostatic module, but the color is orange and show ''unexpected unit of input'' so i can't use it in boundary condition ad i can't solve my problem Appreciate much for your help!!
