geometry import - subdomain conflict
Dear All,
I am trying to do the following: import an assembly drawn in Inventor into Comsol. I exported the file from Inventor as a *.stp file and imported that into Comsol. The file is imported without any obvious problems.
Later, I need to define a point load in a part of the body that I have imported. Unfortunately, there is no point on where I need to define the point load, so I inserted an additional point using draw, in Comsol GUI. Then I got the error message:
"internal error on geometry decomposition".
I tried to import the geometry as surface instead of solid and checked the use assembly, which led to be able to place the point where I want without getting error messages, but now I cannot assign my point load, as the point appears gray (inactive) in the point list in the point settings menu.
To sum up, I am trying to import a 3D model into Comsol and define a specific point in that body to be able to apply a point load. Any ideas how to do it?
1 Reply Last Post Nov 23, 2010, 5:31 a.m. EST
Posted: 1 decade ago Nov 23, 2010, 5:31 a.m. EST
the easiest to get a point on a suface is to split a sirface along two lines intesecting at the point, then you can select points and/or lines and use them easily as metrology elements.
But note, loading a 2D or 3D structure via a point is a singularity and your results will be doubptfull around the point, whatever you select as mesh
Hi the easiest to get a point on a suface is to split a sirface along two lines intesecting at the point, then you can select points and/or lines and use them easily as metrology elements. But note, loading a 2D or 3D structure via a point is a singularity and your results will be doubptfull around the point, whatever you select as mesh -- Good luck Ivar
