ACDC PROBLEM: OPERATORS WORK FOR APPLICATION MODE VARIABLES BUT NOT FOR PROJECTION COUPLING VARIABLES
HELLO TO ALL OF YOU:
I AM WORKING IN COMSOL 3.5 A, IN AXISYMMETRY MODE, ACDC, AZIMUTHAL INDUCTION CURRENT, TRANSIENT ANALYSIS.
In File>Export>Postprocessing Data>Subdomain>Expression: I wrote
Bz_emqa and later I also wrote d(Bz_emqa,z)
and exported successfully both sets of data to the same subdomains (all my subdomains) and got good plots.
But,
In Options>Projection Coupling Variables>Subdomain Variables I wrote:
SOURCE
Name Expression Integration Order
magflux (Bz_emqa*2*pi*r)*((r>=0)&&(r<=7.25E-3)&&(z>=-21E-3)&&(z<=21E-3)) 4
General Transformation
x : z
y : r
DESTINATION
Level: Sub domain x : z ***I made this available in ALL DOMAINS***
With this I got the magnetic flux from -21mm<=z<=21mm through a circle of 7.25 mm radius
QUESTION:
FOR THE APPLICATION MODE VARIABLES THE FIRST DERIVATIVE OF Bz_emqa WITH RESPECT TO Z WORKED OUT OK, BUT IF I TRIED TO POST PROCESS IN THE SAME WAY I EXPLAINED ABOVE, WRITING IN THE SUB DOMAIN EXPRESSION FIELD: d(magflux,z) I GET ONLY ZEROS!
When I try to export d(magflux,z) it doesn't work at all!
WHY d(variable, coordinate) is working for the APPLICATION MODE VARIABLE, but not for the variable I defined (which is the line integration over horizontal lines of Bz_emqa, made available in ALL DOMAINS, and done for different values of z) ?????? When I try to export d(magflux,z) it doesn't work at all!
P.S. I always update the model before post processing and make sure I selected the variable I need.
At this moment I am doing a static analysis, and I don't have any time dependent variable.
THANK YOU ALL!!!!
0 Replies Last Post Dec 29, 2010, 9:34 a.m. EST
Hello Igor P.
