Evaluating integral results
I want to do some calculations using the results from surface integration in axi-symmetric mode. I am calculating the volume of some of the subdomains by just integrating 1 across the different volumes. The problems is that I want to evaluate the results from the integrals, but cannot find a way to extract these data from the results table.
For instance:
surf_a=surface integral of subdomain a
surf_b=surface integral of subdomain b
--> Evaluate surf_a/surf_b so I can see the result every time I run the model.
Thanks!
-William
5 Replies Last Post Dec 2, 2014, 3:13 a.m. EST
Posted: 1 decade ago Feb 11, 2011, 7:18 a.m. EST
Hi William
Well first of all check if the volume integration is not rather
intop(2*pi*r*Your_Variable) (or just Your_Variable=1 for the volume) in 2D-axi
you can also for postprocessing integrations (only) turn the automatic 2*pi*r multiplicant by selection in the "integration settings - Compute volume integration" "on"
Then you are easier out by defining an "Definition - Integration operand" and a "Definition - Variable"
My_Variable1 = intop1(2*pi*r*Your_Variable) on a given domain/boundary set
My_Variable2 = intop2(2*pi*r*Your_Variable) on another given domain/boundary set
Definition - Global Evaluation
with My_Variable1 / My_Variable2
By the way you have also the "Probes" that gives you feedback during the solving
Lykke til
Hi William Well first of all check if the volume integration is not rather intop(2*pi*r*Your_Variable) (or just Your_Variable=1 for the volume) in 2D-axi you can also for postprocessing integrations (only) turn the automatic 2*pi*r multiplicant by selection in the "integration settings - Compute volume integration" "on" Then you are easier out by defining an "Definition - Integration operand" and a "Definition - Variable" My_Variable1 = intop1(2*pi*r*Your_Variable) on a given domain/boundary set My_Variable2 = intop2(2*pi*r*Your_Variable) on another given domain/boundary set Definition - Global Evaluation with My_Variable1 / My_Variable2 By the way you have also the "Probes" that gives you feedback during the solving -- Lykke til Ivar
Posted: 1 decade ago Feb 11, 2011, 7:34 a.m. EST
Thanks!
I tried to define the following variable under Model:
mass = intop1(2*pi*r)
but the expression turns orange, and I don't know why. I try to do a Global Evaluation of the variable under Derived Values (Expression = mass), but get the following error:
Failed to evaluate variable
-Variable: mod1.mass
-Global scope:
-Expression: real(mod1.mass_tail)
Thanks! I tried to define the following variable under Model: mass = intop1(2*pi*r) but the expression turns orange, and I don't know why. I try to do a Global Evaluation of the variable under Derived Values (Expression = mass), but get the following error: Failed to evaluate variable -Variable: mod1.mass -Global scope: Failed to evaluate expression. -Expression: real(mod1.mass_tail) Failed to evaluate expression. -Expression: real(mod1.mass_tail)
Posted: 1 decade ago Feb 11, 2011, 9:21 a.m. EST
Orange means check your units !
if you want the mass it's the sum over the "i" selected domains of the integration of solid.rho[kg/m^3] * dx*dy*dz
in 2D- axi a tripple integration is the double integration (over the section area) of 2*pi*r*solid.rho*dr*dz to get a mass =[kg] out
So if you add your "*solid.rho" to you integrand it should be fine
In general you should understand that the values you use in COMSOL are the mesh element items, all to be integrated of the elements hence *dx*dy*dz (in 3D). Just as most COMSOL variables are expressed as denisties in [Units/m^2] or [Units/m^3], all values to be integrate over the boundaries or domains to get the macro values we engineers are used to operate with
Lykke til
Hi Orange means check your units ! if you want the mass it's the sum over the "i" selected domains of the integration of solid.rho[kg/m^3] * dx*dy*dz in 2D- axi a tripple integration is the double integration (over the section area) of 2*pi*r*solid.rho*dr*dz to get a mass =[kg] out So if you add your "*solid.rho" to you integrand it should be fine In general you should understand that the values you use in COMSOL are the mesh element items, all to be integrated of the elements hence *dx*dy*dz (in 3D). Just as most COMSOL variables are expressed as denisties in [Units/m^2] or [Units/m^3], all values to be integrate over the boundaries or domains to get the macro values we engineers are used to operate with -- Lykke til Ivar
Posted: 1 decade ago Feb 11, 2011, 9:49 a.m. EST
Thanks!
The problem got solved when I first defined a Model Coupling Integration for each of the domains, and then defined global equations for the two integrand operators.
Thanks! The problem got solved when I first defined a Model Coupling Integration for each of the domains, and then defined global equations for the two integrand operators.
Posted: 1 decade ago Dec 2, 2014, 3:13 a.m. EST
In a v4.2 mph file, I have two models (model 1 & model 2) each with a geometry. So there are 2 geometries (geom 1 & geom 2) in the same mph file. While postprocessing, I want to do subdomain integration of any 2 solutions, each from the respective geometries. But the data set for subdomain integration seems to accept solution set from any one geometry at a time and it shows error even if I specify geometry 2, e.g: "mod2.emw2.Ex" in the expression field. Can anybody help me in this respect, how solution from a different geometry can be specified in the expression field for subdomain integration ?
thanks
Hi, In a v4.2 mph file, I have two models (model 1 & model 2) each with a geometry. So there are 2 geometries (geom 1 & geom 2) in the same mph file. While postprocessing, I want to do subdomain integration of any 2 solutions, each from the respective geometries. But the data set for subdomain integration seems to accept solution set from any one geometry at a time and it shows error even if I specify geometry 2, e.g: "mod2.emw2.Ex" in the expression field. Can anybody help me in this respect, how solution from a different geometry can be specified in the expression field for subdomain integration ? thanks
