Exporting plot data of a parametric sweep
I have a 1D plot showing some results from a parametric sweep, at all values of the swept parameter. That is, I have several curves in this plot, one corresponding to one value of the parameter. When I export the plot data, the output file contains a concatenated version of all curves. Is there a smart way to recover the sweep parameter value? For example in a third column?
Thank you
Daniel
1 Reply Last Post Apr 10, 2017, 8:07 a.m. EDT
Posted: 8 years ago Apr 10, 2017, 8:07 a.m. EDT
Try the following trick: Add a Color subnode to the plot and set the expression to your parameter.
[QUOTE] Is there a smart way to recover the sweep parameter value? For example in a third column? [/QUOTE] Try the following trick: Add a Color subnode to the plot and set the expression to your parameter.
