Work plane of finite size
Jorge Prada Microsensors
Hello all!, I'm interested into split an object in two domains using a work plane, which passes through 3 vertex lying around a narrow neck. I would like the object to be cut just across that narrow neck. Nevertheless, when using a work plane as cut tool, it extends across other regions of the same object, where I don't want the cut goes through. Please, how can I restrict the cutting extend or how can I limit the work plane extension? Thank you!
Jorge Enrique Prada Rojas
3 Replies Last Post Oct 27, 2017, 10:21 a.m. EDT
Posted: 7 years ago Oct 26, 2017, 1:51 p.m. EDT
Updated: 7 years ago Oct 26, 2017, 2:12 p.m. EDT
Hi Jorge,
You can draw a suitable object in the workplane and partition using that object, as illustrated in the attached file.
Jeff Hiller
Hi Jorge, You can draw a suitable object in the workplane and partition using that object, as illustrated in the attached file. Best, Jeff
Posted: 7 years ago Oct 27, 2017, 9:45 a.m. EDT
Hi Jorge,
Thank you Jeff. It worked fine!
>Hi Jorge, > >You can draw a suitable object in the workplane and partition using that object, as illustrated in the attached file. > >Best, > >Jeff Thank you Jeff. It worked fine!
Posted: 7 years ago Oct 27, 2017, 10:21 a.m. EDT
Glad I could help!
Jeff Hiller
Glad I could help! Best, Jeff
