Mar 29, 2011, 4:48 p.m. EDT
OK.
I managed to get some advance but I keep getting this error:
Error-Failed to find consistent initial values
I don't understand why this happens...
The file is attached.
Hope someone can help.
Thanks.
Cheers.
OK.
Thanks.
Cheers.
Mar 30, 2011, 4:22 a.m. EDT
Anyone?
Anyone?
Apr 7, 2011, 4:01 a.m. EDT
I do not know if you have found your way out, but in the latest 4.1.0.185, if you clear your solution and run it with a new solver setup (+ removes the stationary case) it seems to solve, but I do not know if its correct ;) the diffusion seems to be very slow
Apr 7, 2011, 1:44 p.m. EDT
Hello Ivar,
after contacting Support, they informed that there was a bug with the V4.0a with the slip velocity models.
It was likely that were was not going to be a convergence, due to that particular bug.
So I went back to 3.5a and I did get some results, although I am struggling with the mesh density and
the Solvers.
If you could please upload the modified file, I would be gratefull.
I have recently acquired the 4.1 version.
Thank you very much for your input.
Rui
Hello Ivar,
the Solvers.
Rui
Apr 15, 2011, 10:23 a.m. EDT
take your 14.mph model above, open it in the updated (for me v4.1.0.185) COMSOL session.
Select Solver Configuration, right click "Delete Solvers" then Solve.
To have no errors, even when testing initial conditions, add a "Parameter" t= 0[s] as you refer to "t" and t is only there from the moment the stationary solver acts
I did nothing else and havent stored the file
