How can I get the result along a line?
Now I use comsol to analyze the vibration of the plate and I obtain the vibrational displacement of the plate. I want to obtain the vibrational displacement along a line. For example, The plate is sqaure with dimension 1x1 and I want to see the displacement along the diagonal line. How can I do that?
1 Reply Last Post Dec 26, 2017, 4:11 p.m. EST
Posted: 8 years ago Dec 26, 2017, 4:11 p.m. EST
Zhihui,
you can use a line plot in a 1D plot group. For the line you have two options. 1. Include the line into the geometry. You can then directly select it for the line plot. 2. Create a cut line dataset and use it for the line plot.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Zhihui, you can use a line plot in a 1D plot group. For the line you have two options. 1. Include the line into the geometry. You can then directly select it for the line plot. 2. Create a cut line dataset and use it for the line plot. Cheers Edgar
