Need help connecting points automatically with changing parameters
I am attempting to change the height of a structure using parameters. The structure is very angular, and therefore when the height is changed the lines that connect the base to the top become either not long enough, or too long. In addition, the lines that connect the base and top are no longer at the correct angle with varied heights. Is there a feature that will allow for the lines to constantly snap the base to the top of the structure when the height is changed parametrically? (The lines that are used as connectors are classified as bezier polygons).
1 Reply Last Post Mar 26, 2018, 9:17 a.m. EDT
Posted: 7 years ago Mar 26, 2018, 9:17 a.m. EDT
Hello William,
I am not sure I fully understand your question, but you may be looking for the "lofting" feature of the Design Module, see https://www.comsol.com/design-module .
Jeff Hiller
Hello William, I am not sure I fully understand your question, but you may be looking for the "lofting" feature of the Design Module, see https://www.comsol.com/design-module . Best regards, Jeff
