Particle tracing
I have hard time using particle tracing,
without mass in particle tracing is fine,
but if I put the mass on particle tracing,
the streamline(particle) itself, doesn't move at all,
I don't know the reason why,
I am using comsol 3.5 also, Multiphysics in fluid mechaincs in steady state condition
and I think there are not a lot of example regarding particle tracing,
if someone does have some,
I will be happy if someone shares with me,
thanks a lot have a great day :)
2 Replies Last Post Apr 26, 2012, 9:06 a.m. EDT
Hello Myounggon Kim
Posted: 1 decade ago Dec 5, 2011, 1:11 p.m. EST
BEFORE ALL Update your COMSOL to 4.2a
then
-Check that plot is based on the right solution.
-Increase time in your transient time study.
-Add particle initial velocity (same as boundary u, v)
-Check particle mass
[QUOTE] I have hard time using particle tracing, without mass in particle tracing is fine, but if I put the mass on particle tracing, the streamline(particle) itself, doesn't move at all, I don't know the reason why, I am using comsol 3.5 also, Multiphysics in fluid mechaincs in steady state condition and I think there are not a lot of example regarding particle tracing, if someone does have some, I will be happy if someone shares with me, thanks a lot have a great day :) [/QUOTE] BEFORE ALL Update your COMSOL to 4.2a then -Check that plot is based on the right solution. -Increase time in your transient time study. -Add particle initial velocity (same as boundary u, v) -Check particle mass
Posted: 1 decade ago Apr 26, 2012, 9:06 a.m. EDT
I want to calculate the particle trajectory resulted from fluid flow in a magnetic field based on the following equation:
m*dV/dT= a*dB/dx+ b(V-u)
where B, u and V are magnetic flux density, fluid velocity and particle velocity.
I have simulated the magnetic field (mf) and flow field (laminar flow, spf).
to calculate the trajectories, I have added "Particle tracing for AC/DC" physics and included a "force" node in it.
My question is:
How should I write the right hand side of above equation in the force node?
Can I write:
dB/dx= d(mf.normB,x)
V-u=d(qx,t)-u
Thank you in advance
Hi I want to calculate the particle trajectory resulted from fluid flow in a magnetic field based on the following equation: m*dV/dT= a*dB/dx+ b(V-u) where B, u and V are magnetic flux density, fluid velocity and particle velocity. I have simulated the magnetic field (mf) and flow field (laminar flow, spf). to calculate the trajectories, I have added "Particle tracing for AC/DC" physics and included a "force" node in it. My question is: How should I write the right hand side of above equation in the force node? Can I write: dB/dx= d(mf.normB,x) V-u=d(qx,t)-u Thank you in advance
