problem with if condition
hello,
I have been trying to put condition in heat source
like heat flux= (t>=1e-6)*0+(t<=1e-12)*10e6
and my time dependent:
times: range(1e-6,1e-6,2e-6) range(2e-6,1e-12,2.000010e-6 ) range(2.000010e-6, 1e-6,10e-6)
when I run solution it is not giving me any heat flux!..(as per my idea it should give me heat flux in interval of range(2e-6,1e-12,2.000010e-6 ) but it is not)....... !!!!!
Please kindly reply if any one has idea how to put condition so that heat source will have value!!!
Chirag Patel
3 Replies Last Post Nov 16, 2011, 10:18 a.m. EST
Posted: 1 decade ago Nov 16, 2011, 9:56 a.m. EST
your heat source is only on in the interval [0, 1e-12s], afterwards it is off. I do not clearly understand which time behavior you actually want.
Cheers
Edgar
Hi, your heat source is only on in the interval [0, 1e-12s], afterwards it is off. I do not clearly understand which time behavior you actually want. Cheers Edgar
Posted: 1 decade ago Nov 16, 2011, 10:09 a.m. EST
hi, Edgar,
thanks for your interest in my problem,
I want that my hear flux shoud be 0 in interval of range(1e-6,1e-6,2e-6) and range(2.000010e-6, 1e-6,10e-6)
And I should get heat source in interval of range(2e-6,1e-12,2.000010e-6 ), as per my condition!!!
but I am not getting any heat flux!!!
Thanks in advance ...
Chirag Patel
hi, Edgar, thanks for your interest in my problem, I want that my hear flux shoud be 0 in interval of range(1e-6,1e-6,2e-6) and range(2.000010e-6, 1e-6,10e-6) . And I should get heat source in interval of range(2e-6,1e-12,2.000010e-6 ), as per my condition!!! but I am not getting any heat flux!!! Thanks in advance ... Chirag Patel
Posted: 1 decade ago Nov 16, 2011, 10:18 a.m. EST
hi, Edgar,
Thank you very much... I got your point!!!..
Now it is working!!!
Chirag Patel
hi, Edgar, Thank you very much... I got your point!!!.. Now it is working!!! Chirag Patel
