meshing elements
My PI would like to know how many meshing elements are in my model. Is there a way to look this up somewhere within the model? Or in the log, as the program is running?
Thank you!
Kelley
2 Replies Last Post Jul 19, 2012, 1:29 a.m. EDT
Posted: 1 decade ago Jul 18, 2012, 5:15 p.m. EDT
I found it, but I thought I would put the answer in here in case someone else is looking for the same thing some day.
Once you start a run, one of the first things the model does is layout all the elements in your model in the log window. So look at an old log, or start a new run and watch the log window until it says something like...
Number of vertex elements: 5053
Number of edge elements: 19008
Number of boundary elements: 65226
Number of elements: 267105
Free meshing time: 29.63s
Minimum element quality: 0.07098
Number of edge elements: 19224
Number of boundary elements: 70410
Number of elements: 445525
Free meshing time: 3.03s
Minimum element quality: 0.0002457
Nonlinear solver
Number of degrees of freedom solved for: 1141680.
I found it, but I thought I would put the answer in here in case someone else is looking for the same thing some day. Once you start a run, one of the first things the model does is layout all the elements in your model in the log window. So look at an old log, or start a new run and watch the log window until it says something like... Number of vertex elements: 5053 Number of edge elements: 19008 Number of boundary elements: 65226 Number of elements: 267105 Free meshing time: 29.63s Minimum element quality: 0.07098 Number of vertex elements: 5053 Number of edge elements: 19224 Number of boundary elements: 70410 Number of elements: 445525 Free meshing time: 3.03s Minimum element quality: 0.0002457 Nonlinear solver Number of degrees of freedom solved for: 1141680.
Posted: 1 decade ago Jul 19, 2012, 1:29 a.m. EDT
you can also right click on the Mesh node and ask for statistics, then you can select the full or a part of your model
Hi you can also right click on the Mesh node and ask for statistics, then you can select the full or a part of your model -- Good luck Ivar
