extract data to matlab
when running time dependent simulation, how can I extract the results of the evolution of the variable under study
to a txt file ? or to matlab?
I mean, whereabouts in comsol is that option?
thank you
5 Replies Last Post Jul 27, 2012, 1:16 p.m. EDT
Posted: 1 decade ago Jul 23, 2012, 7:56 a.m. EDT
To connect COMSOL and MATLAB, you'll need the LiveLink for MATLAB: www.comsol.com/products/livelink-matlab/
To connect COMSOL and MATLAB, you'll need the LiveLink for MATLAB: http://www.comsol.com/products/livelink-matlab/
Posted: 1 decade ago Jul 25, 2012, 2:05 p.m. EDT
Posted: 1 decade ago Jul 25, 2012, 2:16 p.m. EDT
when I downloaded COMSOL 4.2a, with it came together another application "COMSOL 4.2a with MATLAB" , but when I click there it open like a comand line (where I cant write anything), and the comsol or matlab are not automatically opened.....
also I tried to open matlab and comsol after, but nothing appeared on that "comand line".. sounds like it does not fit for anything.....
when I downloaded COMSOL 4.2a, with it came together another application "COMSOL 4.2a with MATLAB" , but when I click there it open like a comand line (where I cant write anything), and the comsol or matlab are not automatically opened..... also I tried to open matlab and comsol after, but nothing appeared on that "comand line".. sounds like it does not fit for anything.....
Posted: 1 decade ago Jul 25, 2012, 4:48 p.m. EDT
check the instalation doc, you need matlab already installed, and define the link to matlab during the COMSOL install, the first time you open the link you are requested for your user name and pasword, to get the link up working, as it loops around a "pseudo" network link to communicate between the two programmes
Hi check the instalation doc, you need matlab already installed, and define the link to matlab during the COMSOL install, the first time you open the link you are requested for your user name and pasword, to get the link up working, as it loops around a "pseudo" network link to communicate between the two programmes -- Good luck Ivar
Posted: 1 decade ago Jul 27, 2012, 1:16 p.m. EDT
Hi Ivar
I'm getting some errors
I'm using MATLAB R2010a
and COMSOL 4.2a
is there the possibility non compatibility?
Hi Ivar I'm getting some errors I'm using MATLAB R2010a and COMSOL 4.2a is there the possibility non compatibility?
