Laminar inflow into a turbulent domain
I have a 3D geometry in which turbulent flow develops downstream, but the inlet to the domain is a pipe that has laminar inflow. The turbulence physics interfaces do not have a laminar inflow boundary condition like the laminar flow interface does. What is the best way to apply a laminar inflow condition in this case?
In the distant past (pre-3.5) I was able to solve Poisson's equation on a disk to get the laminar profile and then couple that to the inlet boundary. I cannot figure out how to do that in 4.3a.
Any help would be appreciated.
Steven Conrad, MD PhD
LSU Health
5 Replies Last Post Apr 5, 2013, 7:22 p.m. EDT
Posted: 1 decade ago Apr 4, 2013, 1:41 a.m. EDT
I would say as in 3.5: you add a 2nd model, in the first mod1 you solve your 2D case, in the mod2 the 3D case and you get either a model coupling projection operator to map the two surfaces from mod1 to mod2, or you play with the equations to transfer the pertinent _u_,p vector/scalar fields from one to the next.
On the other hand, I usually set up a parabolic velocity profile and manage to work with that, less precise but even quicker to define
Hi I would say as in 3.5: you add a 2nd model, in the first mod1 you solve your 2D case, in the mod2 the 3D case and you get either a model coupling projection operator to map the two surfaces from mod1 to mod2, or you play with the equations to transfer the pertinent _u_,p vector/scalar fields from one to the next. On the other hand, I usually set up a parabolic velocity profile and manage to work with that, less precise but even quicker to define -- Good luck Ivar
Posted: 1 decade ago Apr 4, 2013, 7:20 p.m. EDT
Thanks, Ivar
It seems the second approach is easier. I created an analytical function that defines a 2D parabolic profile, but cannot see how to apply it as a boundary condition on a particular boundary. I thought I could use the variables s1 and s2 as function parameters to 'fit' the function to the 2D inlet boundary as a velocity, but I it returns that s1/s2 could not be evaluated.
Any ideas or suggestions?
LSU Health
Thanks, Ivar It seems the second approach is easier. I created an analytical function that defines a 2D parabolic profile, but cannot see how to apply it as a boundary condition on a particular boundary. I thought I could use the variables s1 and s2 as function parameters to 'fit' the function to the 2D inlet boundary as a velocity, but I it returns that s1/s2 could not be evaluated. Any ideas or suggestions? -- Steven Conrad, MD PhD LSU Health
Posted: 1 decade ago Apr 5, 2013, 1:57 a.m. EDT
"s" works fine for 2D, but in 3D there is always some ambiguities.
So what I usually do is to place a cylindrical coordinate system (Model Definitions Coordinates) and define the formula directly as an equation depending on the sys2.r variable
Hi "s" works fine for 2D, but in 3D there is always some ambiguities. So what I usually do is to place a cylindrical coordinate system (Model Definitions Coordinates) and define the formula directly as an equation depending on the sys2.r variable -- Good luck Ivar
Fabrice Schlegel COMSOL Employee
Posted: 1 decade ago Apr 5, 2013, 11:41 a.m. EDT
Dear Steve,
To specify the velocity profile on the boundary, I would recommend following Ivar’s advice and specify the velocity profile as a function of the x,y,z coordinates rather than s1 and 2. In the attached model, I modified the backstep model from the model library and input a parabolic velocity profile.
The expression for such a profile is u=U_Max*(1-r^2/R^2) . Integrating this on the inlet surface, you get that U_Max= 2*U_Mean. Therefore, I used the following expression for the inlet velocity:
2*v_mean*(1-r^2/R^2)
The radius r is defined in the variable table as a function of y and z. Please let me know if you have more questions.
Dear Steve, To specify the velocity profile on the boundary, I would recommend following Ivar’s advice and specify the velocity profile as a function of the x,y,z coordinates rather than s1 and 2. In the attached model, I modified the backstep model from the model library and input a parabolic velocity profile. The expression for such a profile is u=U_Max*(1-r^2/R^2) . Integrating this on the inlet surface, you get that U_Max= 2*U_Mean. Therefore, I used the following expression for the inlet velocity: 2*v_mean*(1-r^2/R^2) The radius r is defined in the variable table as a function of y and z. Please let me know if you have more questions.
Posted: 1 decade ago Apr 5, 2013, 7:22 p.m. EDT
Thanks, Fabrice, Ivar
I will implement this approach. Is is reasonable that this boundary condition should be available in the turbulent flow interface as it is in the laminar flow? If so, I can submit as a feature request.
LSU Health
Thanks, Fabrice, Ivar I will implement this approach. Is is reasonable that this boundary condition should be available in the turbulent flow interface as it is in the laminar flow? If so, I can submit as a feature request. -- Steven Conrad, MD PhD LSU Health
