How to fix range of the legend for time dependent simulation results?
I am using COMSOL for time dependent simulations. While visualizing the results, the legend rescales depending on the solution range for each timestep. This prevents comparison of results between two timesteps.
Can anybody suggest, how to fix the legend range constant for all the results?
1 Reply Last Post Oct 13, 2013, 6:35 p.m. EDT
Posted: 1 decade ago Oct 13, 2013, 6:35 p.m. EDT
in the plot (3D or 2D) connected to your time dependent step, go to "Range" and in "Manual color range" you can specify the max and min values to be assigned to the colour scale. Of course, you should know the max and the min value (over the entire time range) of the variable you want to plot.
I hope this helps
Cheers
Hi, in the plot (3D or 2D) connected to your time dependent step, go to "Range" and in "Manual color range" you can specify the max and min values to be assigned to the colour scale. Of course, you should know the max and the min value (over the entire time range) of the variable you want to plot. I hope this helps Cheers
