mass conservation
Posted Aug 22, 2014, 8:01 a.m. EDT Plasma Physics, Chemical Reaction Engineering Version 4.4 13 Replies
can somebody tell me, if the continuity equations needs to be fulfilled for a background gas species (in DC discharge plasma or diluted species) if I am not interested in the distribution of this species. The background species decays in a reversible reaction to electron and ion.
When I use the real values for pressure and velocity profile of the background gas species I get a wrong solution for the ion fluxes (production rate and outgoing fluxes are not the same). This is maybe due to a discontinuity in the used real velocity field (there is entering gas in the middle of a tube and pumped out at both ends, therefore in the middle there is a step in the velocity from -v to +v). Using a simple linear profile from -v_out to +v_out for the background gas gives a better solution (rate and outgoing flux for the reactants are equal). I know, in this case mass for the background gas is not conserved, but I am not interested in that gas, I am just interested in the pressure and velocity distribution of ions/electrons.
Laura
Yes, I believe the continuity equation must be fulfilled to get a consistent solution. Since the software is solving for the mass fraction of the ions, any non-conservation of the total mass should lead to non-conservation of the ion mass.
Luke Gritter
AltaSim Technologies
To me it seems this kind of problem, that the background does not considerably change such that it's change has an influence on the dynamics. So you can set this field at an easily predictable value.
the gas density comes from gas dynamic simulation. The background gas density decreases towards the ends to about 0.05- 0.02 of the density at the injection in the middle of the tube. Therefore the velocity of the background gas also changes considerably. And it changes sign, as the gas flows to both ends of the tube. I tried a 2D plasma model. There I take the background gas density and velocity from a gas flow (transitioal flow) simulation. But I don't know, if I have to define any inlets/outlets for the background gas .
I get the error:
Detail: Undefined value found in the stiffness matrix.
There are 3864 equations giving NaN/Inf in the matrix rows for the variable comp2.Ne2
This comes only when taking the plasma density (or pressure) from the transitional flow simulation (tran.N) when I choose another distribution for the pressure the simulation runs.
I did simulation without a convective term, there everything works and results make sense. The problem is the convective term (from the background gas flow) that can not be ignored for the ion motion...
I attached the model file...
For some reason, the software is initially seeing a zero or negative pressure when the solution process is begun. I'm not sure of the reason for this (it does not appear to be caused by the interpolation to the new mesh), but it can be easily remedied by using an expression such as max(1e-3,tran.N*1.381e-23[J/K]*30[K]) for the pressure. Make sure that the cutoff value (1e-3 in the example) is below the minimum value from the flow simulation so that the solution is not affected.
Also, in the "Values of variables not solved for", change the method from "Initial Expression" to "Solution".
Luke Gritter
now the model is running. But there still seems tobe a problem with the in- and outgoing fluxes. The incomming flux is the integrated T+ rate (respecting the recombination). The outgoing flux is the integrated (convective, diffusive and migrative) flux at each boundary in -1*normal direction. When comparing both fluxes, the incomming ammount of tritium is larger than the outgoing ammount although the solution has reached the stationary state. Do you know how this could be?
I tried the same problem in 1D, there I had the same problem with the not-matching fluxes. This came from the discontinuity of the velocity in the middle of the tube which seemed to work as an effective ion inlet.
But this should not be the case in my 2D simulation, as there is a "real" gas injection.
How large is the difference between the net production and the outgoing flux? Could you upload the 2D model in which you see the discrepancy?
Luke Gritter
in the model I attached the difference is up to four orders of magnitude. The flux that goes out is much larger than the created number of ions.
When I look at the 1D ion flux in y direction on the edges up and down, I can see that there is a large incoming flux in the middle of the tube (where the backround gas inlet is in the transitional flow). There should just be an tritium gas (backround gas) inlet in the middel of the tube and no ion inlet. Maybe this is the problem? But how can I change it?
The strange thing is that in my other attemps (witout including the transitional flow directly) the discrepancy was not that large and the rate of created number of ions was larger than the outgoing flux, the outgoing flux was ten times smaller than the creation rate.
Laura
Now the incomming rate and outgoing flux for the ions is sitll different, but its much closer (sum outgoing fluxes: 1.6e13 (ms)^-1, integrated rate: 2.1e13 (ms)^-1 ).
However there is still a difference between both fluxes. Do you know why?
The potential inside the tube is much larger than we expected (and then was found in the 1d-model). We expected the potential to be dominated by the left (tube end) potential . In this model this should result in a quasi zero potential. But the solution is far away... This is due to the ion density (and space charge) distribution that looks also kind of strange to me...
Regards Laura
Both Inlet and Outlet boundary conditions should be defined for T+. The Inlet boundary condition for T is not actually being used because T is not being solved for. When I add an Inlet boundary condition for T+, I get a total outgoing flux of 2.2e13 and an integrated rate of 2.4e13. The 10 % discrepancy is still a bit high, but it could possibly be improved by means of a finer mesh.
Luke Gritter
thanks for your helpful answear. I tried to implement th T+ inlet but somehow I cannot get a solution for the model. Either there are these strange potential values or the solver gives the error that it can't find appropriate initial conditions.
so can you maybe upload your model file that worked for you with the inlet?
Laura
Thank you for your help
Can you please upload your model that gave you the right solution?
Maybe I took a to coarse mesh size or something like that.
Regards
Laura
I've attached the file (the solutions have been cleared). The high electric potential is due to the boundary conditions - the electrons are lost at the upper and lower boundaries, but the ions are not, leading to a large positive space charge.
Luke Gritter
