"square/rectangle" pulse generation in V 3.5a
I am trying to provide a square voltage pulse into my model. Does anyone know how to provide a rectangular or sinusoidal signal ? I am using 3.5a V.
4 Replies Last Post Jun 20, 2011, 1:41 p.m. EDT
Posted: 1 decade ago Jul 7, 2010, 8:44 a.m. EDT
Rectangular pulse should be difficult, if not impossible. Try checking if they have heaviside functions in Comsol. But even then, I am unsure if you would be able to have high enough sampling to capture that jump discontinuity. I would rather suggest you to think along a ramp pulse which has the added advantage of being physically possible.
Providing sinusoidal signal is easy. Use sin(f0*t) by specifying the value of frequency f0. I would also suggest you to search this topic in forum's archive. There should be something interesting.
All the best.
Rectangular pulse should be difficult, if not impossible. Try checking if they have heaviside functions in Comsol. But even then, I am unsure if you would be able to have high enough sampling to capture that jump discontinuity. I would rather suggest you to think along a ramp pulse which has the added advantage of being physically possible. Providing sinusoidal signal is easy. Use sin(f0*t) by specifying the value of frequency f0. I would also suggest you to search this topic in forum's archive. There should be something interesting. All the best.
Posted: 1 decade ago Oct 12, 2010, 7:43 a.m. EDT
Hi!
If I understood you correctly, you can define square pulse of duration 'pulse_width' and pulse period of 'pulse_period' just simply by the following variable
pulseON=(mod(t,pulse_period)<=pulse_width)
Then you just multiply your time-dependent variable with pulseON.
flow_pulsed = flow * pulseON
let's say
pulse_width = 1 s
pulse_period = 5 s
then for
t = 0.5 s pulseON = 1
t = 1 pulseON = 1
t = 3 pulseON = 0
t = 10.5 pulseON = 1
t = 22 pulseON = 0
Hope I got you right.
Hi! If I understood you correctly, you can define square pulse of duration 'pulse_width' and pulse period of 'pulse_period' just simply by the following variable pulseON=(mod(t,pulse_period)
Posted: 1 decade ago May 13, 2011, 2:41 p.m. EDT
I wonder if you manged to solve the problem
Hi, I wonder if you manged to solve the problem
Posted: 1 decade ago Jun 20, 2011, 1:41 p.m. EDT
Dear Andriy:
I tried to use the suggestion given by you on the blog and also tried to implement different suggestions on the Comsol Forum , but I havenot achieved desired result.
My Objective: Pulse width = 0.5ms, frequency = 10Hz, period = 1/frequency = 0.1s. Heating for 1sec and cooling for 5 sec.
Baed on your suggestion, pulseON=(mod(t,pulse_period)<=pulse_width), which is writen in my model as follows
Heat flux = avg_pd_new1 = avg_pd*(mod(t,0.1)<=5e-4)
My problem is : Even if I get the plot of pulse train of frequecy 10Hz and pulse width 0.5 ms, which I can plot on analytic function (an1), but my output remains ON only for the first pulse and rest is OFF.
Also, I did tried several other suggestion, which is plot in analytic function as an2,an3
Please suggest me some solution. I am attaching my model for reference.
Hitesh
Dear Andriy: I tried to use the suggestion given by you on the blog and also tried to implement different suggestions on the Comsol Forum , but I havenot achieved desired result. My Objective: Pulse width = 0.5ms, frequency = 10Hz, period = 1/frequency = 0.1s. Heating for 1sec and cooling for 5 sec. Baed on your suggestion, pulseON=(mod(t,pulse_period)
