Edgar J. Kaiser
Certified Consultant
10 years ago
May 27, 2015, 5:11 p.m. EDT
You can make the material property a function of the spatial coordinates like for a density rho = f(x,y,z). You can do that in COMSOL.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
10 years ago
May 28, 2015, 1:54 a.m. EDT
I do not need the material properties to change with the spatial coordinates, while rather change with the specific discretized element (depending on the mesh). I want the properties to change, say, the density rho as a function of the element, each element here regarded as a single domain.
I know how to assign different properties to different domains. But the problem is that here I want the deleberately treat each element as an indepent domain, to which I want to assign a different value. If I just make the material property as a function of the spatial coordinates, how to make sure that it exactly belongs to the very domain (the very element here).
I come up with an idea that I first draw the geometry with the domains, then I mesh the geometry with the elements just as the size of the domains of the geometry (each element now is corresponding to a separate domain), and under the "materal node" I create separate material nodes which are assigned to separate domains, but the work is enormous if I enlarge the meshed element, which means I have to assign hundreds or even thousands of seperate material nodes. Any simple or convenient method ? By making the material properties change with element, any function or code is capable of implementing this? Or script with matlab? Many thanks.
Venn Wu
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Venn Wu
[QUOTE]
Cheers
Edgar
Edgar J. Kaiser
[/QUOTE]
