Robert Koslover
Certified Consultant
Aug 19, 2010, 11:18 p.m. EDT
I'll take a guess. When a problem includes regions that are both large and small (detailed), the default mesh settings are sometimes inadequate to handle it. I recommend you set up some interior boundaries (without boundary conditions, which should default to continuous conditions) and then define the fineness of the mesh independently in the small and large regions. Alternatively, once you have divided it up as I said, you can mesh the problem on a per-domain basis, in which case you may find it advantageous to mesh the finer domains *before* you mesh the coarser adjoining ones. That makes it easier for the meshing routine to figure out where to insert mesh points.
Mar 29, 2011, 4:55 a.m. EDT
Hi Robert,
I also have the same with meshing of the airgap in an induction machine. Can you explain this solution more clearly?
Thank you
Hi Robert,
Thank you
Mar 29, 2011, 3:33 p.m. EDT
I have noticed often issues when a geometry contains multiple loops, in these cases its often useful to add some interiour boundaries, and mesh "by parts/sections" manually
