Sep 21, 2010, 1:09 a.m. EDT
if you are in 2D and you apply a load to an edge you can use the rod length parameter "s" that varies from 0 to 1 along the edge in the direction of the arrow (edge mode). Just type F=F0*s and you get a forceincreasing from 0 to F0 along he edge, you can use a second order function too.
The other way is to use the coordinates x,y, easy if the edge i along one coordinate, but you must normalise to the edge length (that can be calculated via an integration coupling variable.
In 3D for a surface/boundary its slighly more complex as s1 and s2 are not always varying from 0-1 and their orentation is not always trivial. Then the coordinate mapping way is the best.
Sep 21, 2010, 5:56 p.m. EDT
Ivar,
Thank you for response. I was able to apply a function to the edge length, s1, in my 3D model using your suggestion. s1 scaled with the length of the test bar, so it made it easy when calling the length of the test bar in the function to determine the load applied.
Robb Morris
Ivar,
Robb Morris
