How can I define nonlinear electric conductivity ?
I'm currently working on electrical simulation using AC/DC module. How can I define nonlinear electric conductivity of zinc oxide (ZnO) in subdomain settings?
2 Replies Last Post Jan 20, 2013, 10:41 p.m. EST
Posted: 1 decade ago Jan 20, 2013, 1:29 p.m. EST
which kind of non linearity ? material properties depending on T, or V or I or B-H ? I would say, addthe corresponding a material property as an interpolated function, and be sure your variables are defined and solved for, then it should be "automatic"
Hi which kind of non linearity ? material properties depending on T, or V or I or B-H ? I would say, addthe corresponding a material property as an interpolated function, and be sure your variables are defined and solved for, then it should be "automatic" -- Good luck Ivar
Posted: 1 decade ago Jan 20, 2013, 10:41 p.m. EST
You can check out the Inductive Heating example in the COMSOL Model Gallery (Model ID 148: www.comsol.com/showroom/gallery/148/). It has a nonlinear electrical conductivity.
You can check out the Inductive Heating example in the COMSOL Model Gallery (Model ID 148: http://www.comsol.com/showroom/gallery/148/). It has a nonlinear electrical conductivity.
