Can not open Comsol with "An unexpected error occurred"
hi everyone
Yesterday, I used Comsol normally, but today I can not open it anymore. It gives me this error and its details:
"An unexpected error occurred."
'.', hexadecimal value 0x00, is an invalid character.
at System.Xml.XmlEncodedRawTextWriter.InvalidXmlChar(Int32 ch, Char* pDst, Boolean entitize)
at System.Xml.XmlEncodedRawTextWriter.WriteElementTextBlock(Char* pSrc, Char* pSrcEnd)
at System.Xml.XmlEncodedRawTextWriter.WriteString(String text)
at System.Xml.XmlWellFormedWriter.WriteString(String text)
at System.Xml.Linq.ElementWriter.WriteElement(XElement e)
at System.Xml.Linq.XElement.WriteTo(XmlWriter writer)
at System.Xml.Linq.XNode.GetXmlString(SaveOptions o)
at Comsol.Command.BridgeCommand.ToCommandString()
at Comsol.Communication.ChannelBasedCommandManager.SendCommand(OutgoingCommandHandler commandHandler)
at Comsol.Communication.BridgeCommandManager.OutgoingCommandHandler.Run()
at Comsol.Communication.BridgeCommandManager.RunAndWait(BridgeCommand command)
at ComsolDesktop.MainWindow.StartJava(Boolean debug, Boolean devPlugins, NDisconnectInfo disconnectInfo, IBridgeCommandManager oldMgr)
at ComsolDesktop.MainWindow.StartJava(Boolean debug, Boolean devPlugins)
at ComsolDesktop.App.OnStartup(StartupEventArgs e)
at System.Windows.Application.<.ctor>b__1(Object unused)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
is there anyone has some ideas about this problem ?
Many thanks
Duc
12 Replies Last Post Aug 29, 2017, 2:23 p.m. EDT
Posted: 10 years ago Feb 17, 2015, 7:11 a.m. EST
I have the same problem, comsol worked just fine one minute ago and now this.
Posted: 10 years ago Feb 17, 2015, 8:52 a.m. EST
Hi Hugo
I have just reinstalled my Win and then the Comsol. Now, it works well. :D
Hi Hugo I have just reinstalled my Win and then the Comsol. Now, it works well. :D
Posted: 10 years ago Apr 24, 2015, 3:16 a.m. EDT
Re installing windows is the only option left. Do you know any other way?? Please help....
Posted: 10 years ago Apr 24, 2015, 4:15 a.m. EDT
Sorry ...
I did not have.
Sorry ... I did not have.
Posted: 10 years ago May 25, 2015, 1:10 p.m. EDT
br.comsol.com/support/knowledgebase/1177/
Solution
This issue has so far only been observed on Windows installations. The solution is to ask the to rename/remove the vXX folder located at
C:\Users\%USERNAME%\.comsol\vXX
where %USERNAME% is the user name of the user and XX is the version you are using (44 or 50). If you have important settings in your vXX folder, it is recommended to rename it rather than removing it.
https://br.comsol.com/support/knowledgebase/1177/ Solution This issue has so far only been observed on Windows installations. The solution is to ask the to rename/remove the vXX folder located at C:\Users\%USERNAME%\.comsol\vXX where %USERNAME% is the user name of the user and XX is the version you are using (44 or 50). If you have important settings in your vXX folder, it is recommended to rename it rather than removing it.
Posted: 9 years ago Mar 8, 2016, 7:39 a.m. EST
Thank you Daniel Lau. It works. Thanks for the short technique to repair it.
Posted: 8 years ago Aug 17, 2016, 7:28 p.m. EDT
Thank you! It worked perfectly here
Posted: 8 years ago Sep 4, 2016, 1:23 p.m. EDT
Thank you very much it works !!
Posted: 8 years ago Sep 6, 2016, 6:29 p.m. EDT
Thank you very much. It worked.
Posted: 8 years ago Nov 14, 2016, 4:00 a.m. EST
Thank you, it works perfectly !
Posted: 8 years ago Feb 16, 2017, 5:34 a.m. EST
Thank you Daniel.
This technique really works
Thank you Daniel. This technique really works
Posted: 7 years ago Aug 29, 2017, 2:23 p.m. EDT
thanks alot my problem solved
