SolidWorks - geometry parametric sweep
Posted Oct 7, 2010, 5:44 p.m. EDT 1 Reply
Hello all,
I am using the livelink for Solidworks to maintain the geometric relationships between COMSOL and SolidWorks. However, I would like to run a parametric sweep of one of the geometry parameters but I can not determine how to accomplish this task. I can change the parameter manually under "livelink for SolidWorks/Parameters in CAD package" and the model in COMSOL and SolidWorks both update.
In the parametric sweep box, there is no parameter available for me to select. Also, if I set the parameter in the global/parameters section (to make it available in the parametric sweep box), how to link this parameter to the parameter under the "solidworks/parameter" table.
I am using COMSOL 4.0a and SolidWorks 2010.
How can set up a model to vary a geometric parameter under the "livelink for solidworks/parameter" table?
also, I do not want to use Matlab right now. I already have a script where I am communicating with COMSOL for other items, but do not want to involve Matlab at this stage of the model.
Thank you,
Kevin
Thank you,
Kevin
1 Reply Last Post Oct 10, 2010, 5:44 a.m. EDT
