liquid vapor interface in laser drilling problems
Can we modify the continuity equation in laminar two phase level set, i wish to incorporate evaporation effect which require a source term instead of "0", in the continuity equation?
www.comsol.co.in/paper/keyhole-formation-during-spot-laser-welding-heat-and-fluid-flow-modeling-in-a-2d-13189
1 Reply Last Post Dec 5, 2016, 8:00 a.m. EST
Hello Shashank Sharma
Posted: 8 years ago Dec 5, 2016, 8:00 a.m. EST
Yes, you can.
Under "equation view" mode, select the equation view of "fluid properties" and, under weak expression you find the line:
-tpf.divu*test(p)
Replace it with:
-tpf.divu*test(p)+your_source_term*test(p)
and you modified the continuity equation.
Yes, you can. Under "equation view" mode, select the equation view of "fluid properties" and, under weak expression you find the line: -tpf.divu*test(p) Replace it with: -tpf.divu*test(p)+your_source_term*test(p) and you modified the continuity equation.
