Calculate flux through surfaces in 2D axial symmetry
Posted Oct 14, 2010, 3:51 a.m. EDT 1 Reply
I am trying to calculate the flow/flux of a liquid through a surface in a laminar flow model, but have troubles getting correct values. The model is a simple 2D axial symmetry model. I have a inlet and an outlet (controlling the flow) .
To test how it works I try to calculate the flow using a line integral on the outlet using a selection (choosing only the outlet). With a global evaluation I calculate the following:
w*OutletRad^2*pi
But this will not give me the correct values. If I do
w*OutletRad*pi [m]
I come close, but I don't understand why (as I understand the integral it should normalize for the length of the line it integrates). It seems like the error becomes bigger if i try to do the same evaluation on other surfaces in the model where the flux should be the same (non-compressible flow and pressure constraint)
I have also tried to use the reacf(w) and putting this in a line-integral evaluation and set it to do a surface integral (can do this because of the axial symmetry). This method gives me a flux of 0
Any suggestions or comments to my methods
Best
w*OutletRad^2*pi
w*OutletRad*pi [m]
Best
1 Reply Last Post Oct 17, 2010, 5:23 a.m. EDT
