How to debug MATLAB function (COMSOL 4)
I am able to declare MATLAB function in comsol.
When I run comsol, it gives me error "Incorrect size of returned vector. 596 elements were expected, but the returned matrix was 1 x 1"
The error is OK because my function returns only 1 number, because I am trying to debug it and look on parameters passed by COMSOL. I opened function in MATLAB editor and put breakpoint on it. But it never stops on breakpoint.
In COMSOL 3.5 this works (put breakpoint in MATLAB function).
Is there possibility to trace MATLAB functions?
6 Replies Last Post Apr 20, 2016, 6:07 p.m. EDT
Hello Jakub Zlamal
Posted: 1 decade ago Feb 24, 2011, 9:29 a.m. EST
I have the same problem: I'm trying to set a breakpoint in a Matlab functiona that is being called by Comsol for debugging purposes.
any Idea on how to do that?
I have the same problem: I'm trying to set a breakpoint in a Matlab functiona that is being called by Comsol for debugging purposes. any Idea on how to do that?
Posted: 1 decade ago Feb 24, 2011, 10:23 a.m. EST
It is not possible to debug MATLAB function. (Only possibility is to write debug information in matlab function to file and look at it).
If You change function You must restart comsol to take changes into account or use clearfunction in MATLAB prompt
It is not possible to debug MATLAB function. (Only possibility is to write debug information in matlab function to file and look at it). If You change function You must restart comsol to take changes into account or use clearfunction in MATLAB prompt
Posted: 1 decade ago Nov 5, 2012, 10:36 a.m. EST
My (dirty) solution:
function C = add(a,b)
fid = fopen('/home/user/log','w');
fprintf(fid,'display your debug log\n');
fclose(fid)
end
I use a file as debug log. It works but it's not an ideal solution...
My (dirty) solution: function C = add(a,b) fid = fopen('/home/user/log','w'); fprintf(fid,'display your debug log\n'); fclose(fid) end I use a file as debug log. It works but it's not an ideal solution...
Remi Magnard COMSOL Employee
Posted: 1 decade ago Nov 7, 2012, 4:52 a.m. EST
If you are running COMSOL on Windows you can benefit of the MATLAB debugger.
What you need to do is:
1- Evaluate first the function so that a MATLAB process is started, for instance use the plot button in the function settings tab.
2- At the MATLAB prompt, that should have poped-up automatically to evaluate the function, type: desktop
3- You can now edit the function and add break point.
4- When running the model,the MATLAB debugger automatically stops at the break point and you can verify the intermediate value of the function variables.
This is also described in the LiveLink for MATLAB User's guide: Calling MATLAB function > The MATLAB Function Feature Node > Using the MATLAB Debugger (Windows only), (page 185 in the COMSOL 4.3a documentation)
Enjoy the modeling !
If you are running COMSOL on Windows you can benefit of the MATLAB debugger. What you need to do is: 1- Evaluate first the function so that a MATLAB process is started, for instance use the plot button in the function settings tab. 2- At the MATLAB prompt, that should have poped-up automatically to evaluate the function, type: desktop 3- You can now edit the function and add break point. 4- When running the model,the MATLAB debugger automatically stops at the break point and you can verify the intermediate value of the function variables. This is also described in the LiveLink for MATLAB User's guide: Calling MATLAB function > The MATLAB Function Feature Node > Using the MATLAB Debugger (Windows only), (page 185 in the COMSOL 4.3a documentation) Enjoy the modeling !
Posted: 10 years ago Apr 20, 2016, 2:33 p.m. EDT
I've been searching for a solution to this problem as well. I followed the instructions provided, but when I click 'compute' to run my Comsol model, all of my breakpoints disappear in my matlab functions. Do I need to pass any sort of flag when I type desktop, that enables debugging? Or is this some sort of glitch?
For reference, I am using version 5.1
I've been searching for a solution to this problem as well. I followed the instructions provided, but when I click 'compute' to run my Comsol model, all of my breakpoints disappear in my matlab functions. Do I need to pass any sort of flag when I type desktop, that enables debugging? Or is this some sort of glitch? For reference, I am using version 5.1 Thanks
Posted: 10 years ago Apr 20, 2016, 6:07 p.m. EDT
In case anyone else is having problems, I discovered that if you have 'Clear functions automatically before solving' selected for your Matlab function, it resets all the breakpoints in that function prior to running. This box is useful if you have made any changes to your function since Comsol last used it, but is unnecessary otherwise. If this box is unchecked, you can proceed with debugging.
