Error in Syntax for Modulus of Elasticity
Dear Readers and Moderators of COMSOL,
Hello everyone.
I am using COMSOL 4.a and 4 studying some hygro swelling studies on a particular material.
The syntax on modulus of elasticity ,E, that i would like to input is:
E (MPa) = 0.786T^2 -62.61T+1261
However i encountered so error in inputting the right syntax.
I would like to brought this matter because I don't know how to properly input the proper syntax of the modulus of elasticity as a function of temperature.
I have tried inputting the same syntax shown below into the material property as:
E(0.786T*T-62.61T+1261)[K][MPa]
I just copied this method of inputing the syntax based on the COMSOL tutorial on transient ELBOW BRACKET but COMSOL would recognize it as error.
Please teach me how to input this syntax properly.
I appreciate much if somebody could help me get this right.
Thank you so much in advance.
Jonathan
2 Replies Last Post Oct 16, 2010, 5:44 a.m. EDT
Posted: 1 decade ago Oct 16, 2010, 5:15 a.m. EDT
if you define E as a function (V4) as
(0.786*(T[1/K])^2 - 62.61*T[1/K] + 1261)*1[MPa]
it should do
the T[1/K] set the operand to unitless, and the *1[MPa] sets the units of the function results
Hi if you define E as a function (V4) as (0.786*(T[1/K])^2 - 62.61*T[1/K] + 1261)*1[MPa] it should do the T[1/K] set the operand to unitless, and the *1[MPa] sets the units of the function results -- Good luck Ivar
Posted: 1 decade ago Oct 16, 2010, 5:44 a.m. EDT
Sir Ivar,
Thank you so much Sir Ivar.
I will try your suggestions.
God bless.
Jonathan
Sir Ivar, Thank you so much Sir Ivar. I will try your suggestions. God bless. Jonathan
