Plot of parametric sweep results for a single time
I'm simulating time-dependent laser heating of an object. I plot the temperature vs time at a point probe. Everything is well up to this point. Then I have added a parametric sweep varying the laser power. I would like to generate a plot of temperature vs laser power at a given time, but any table that I generate includes all the times, not just a single time. How do I generate a table of temperature vs power that I can plot? (version 5.2)
2 Replies Last Post Feb 17, 2016, 11:03 a.m. EST
Posted: 9 years ago Feb 17, 2016, 7:45 a.m. EST
The data in probe tables is generated by features in Results > Derived Values. You can either add a new Point Evaluation feature to that list or modify the feature that is used by the probe: Change the list of times to evaluate for from All to the time that you are interested and click on Evaluate > New Table in the Settings window's toolbar.
[QUOTE] I'm simulating time-dependent laser heating of an object. I plot the temperature vs time at a point probe. Everything is well up to this point. Then I have added a parametric sweep varying the laser power. I would like to generate a plot of temperature vs laser power at a given time, but any table that I generate includes all the times, not just a single time. How do I generate a table of temperature vs power that I can plot? (version 5.2) [/QUOTE] The data in probe tables is generated by features in Results > Derived Values. You can either add a new Point Evaluation feature to that list or modify the feature that is used by the probe: Change the list of times to evaluate for from All to the time that you are interested and click on Evaluate > New Table in the Settings window's toolbar.
Posted: 9 years ago Feb 17, 2016, 11:03 a.m. EST
Thank you Gunnar, this worked.
