air flow around the building
I want to request the assistance about the above topic. I chose the Laminar flow in 2D
I had created a model of a building (2D) with length of 20m and H is 26m. The model is placed inside a tunnel (rectangle) with a length of 80m (20m is left of the building and 40 is right of the building). The height is 3xH of a model (80m).
Material is AIR. The inlet is from the left with a velocity of 1m/s while the outlet is from the right end of the rectangle. BC is the building and the bottom part of the rectangle is NO SKIP while the upper part is with a SKIP. Initial value of Pressure is 0Pa.
I entered all the information and data as needed and then compute. The simulation is successfull complete however the RESULT is not go as it is expected.
Anyone can assist in this situation?
0 Replies Last Post Mar 8, 2016, 11:30 p.m. EST
Hello 薩 莫
