Time derivative only allowed with respect to mesh time
Posted Mar 14, 2016, 2:59 p.m. EDT Porous Media Flow Version 5.2 10 Replies
My model contains Darcy's Law under Porous Media and it runs well.
But if I add " Deformed Geometry" Physic under mathematics to compute Time-dependent study, it occurs "Time derivative only allowed with respect to mesh time, expression d(comp1.p,t) "
How can I solve my problem ? Any suggestion ?
N. N
just replace d(comp1.p,t) by d(comp1.p,TIME).
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Thanks a lot for your help !
But I can not find d(comp1.t)!
For example, I use Darcy's Law under porous media. Where can I replace d(comp1.p,t) by d(comp1.p,Time) ?
N. N
However, I don't do CFD, so I can't check your model but other may be willing to do so.
Take care about the spelling, the specifier in the expression has to be TIME, not Time. Case matters!
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Thank you very much !
N.N
Can you help me run CFD module and Deformed Mesh under Mathematics together ?
Replacing d(comp1.p,t) by d(comp1.p,TIME) is a very good solution but I can not find where to do that !
N.N
Good luck.
Thanks a lot for your help ! It's such a amazing idea. It gave me a lot of creative ideas.
But I can not still find weak form under Darcy Module where I can replace d(XXX, t) term to d(XXX, TIME).
Can you help me a little bit more by showing more detail how to do that because I'm a beginner?
N.N
I found where to replace what I want!
Thank you very much one more time !
N.N
Hi Edgar,
In my case, comp1.p is an explicit function of time, and I have it written as comp1.p = t^(-0.5)
I did change d(comp1.p,t) to d(comp1.p,TIME), but I'm getting the error "cannot evaluate negative power of zero". Does this mean that I need to substitute 't' with 'TIME' in the expression for comp1.p as well?
Thanks!
Could you please specify where to modify this equation?
Is it under Analytical Solution settings or PDE settings?
Thank you,
Suggested Content
- FORUM Convergence issues in a problem with time derivative terms in coefficient form PDE module
- KNOWLEDGE BASE Modeling of Step Transitions
- BLOG Using Differential Inductance and Coils in {:comsolmph}
- KNOWLEDGE BASE How to Debug an External Material
- FORUM Operators not Allowed in User Defined Functions
