Custom Linear Solver
I'm wondering whether it is possible to use custom linear solver for my model on comsol.
For example, can I use my original solver implementation instead of MUMPS or PARDISO at Study ->Solver configuration -> Solution -> Direct Solver -> Solver?
1 Reply Last Post Mar 24, 2016, 10:45 a.m. EDT
Posted: 8 years ago Mar 24, 2016, 10:45 a.m. EDT
Seki-
I would recommend looking into using the "Assemble" feature. Right-click on the Solution node which is found within the Study node. Then, select Other>Assemble.
Select the appropriate check boxes for the matrices and vectors you want to inspect or modify and save the model as a model file for Java or export to tabular format. You can then have the raw system matrix data available if you'd like to use your own solver.
Josh Thomas
AltaSim Technologies
Seki- I would recommend looking into using the "Assemble" feature. Right-click on the Solution node which is found within the Study node. Then, select Other>Assemble. Select the appropriate check boxes for the matrices and vectors you want to inspect or modify and save the model as a model file for Java or export to tabular format. You can then have the raw system matrix data available if you'd like to use your own solver. -- Best regards, Josh Thomas AltaSim Technologies
