Invoke parameters from comsol in matlab
Hi everyone,
I would like to invoke parameters from comsol in matlab, the code is as follows
model.param.set('N', '5');
num=model.param.N;
Error in num=model.param.N;
And how to invoke the parameter 'N' in matlab? Is there any other way to do this? Any help is appreciated.
1 Reply Last Post May 26, 2016, 7:53 a.m. EDT
Hello Zhikai Zhao
Posted: 8 years ago May 26, 2016, 7:53 a.m. EDT
In recent versions of Comsol you can do:
[num,unit,expr] = mphevaluate(model, 'N');
which will evaluate the expression for N and returns the numerical value, unit and original definition. In your case it is just a number, but the expressions for parameters can of course be much more complicated than that.
In older versions of Comsol you have to do something like this:
expr = model.param.get('N');
and
value = model.param.evaluate('N')
mphevaluate handles complex parameters automatically. If your parameters are complex you have to use evaluateComplex instead of evaluate in the code above.
Lars Gregersen
Comsol Denmark
Hi In recent versions of Comsol you can do: [num,unit,expr] = mphevaluate(model, 'N'); which will evaluate the expression for N and returns the numerical value, unit and original definition. In your case it is just a number, but the expressions for parameters can of course be much more complicated than that. In older versions of Comsol you have to do something like this: expr = model.param.get('N'); and value = model.param.evaluate('N') mphevaluate handles complex parameters automatically. If your parameters are complex you have to use evaluateComplex instead of evaluate in the code above. -- Lars Gregersen Comsol Denmark
