Hello Marco Formisano
2 decades ago
Jan 12, 2010, 7:21 p.m. EST
Hi Marco!
Good day to you! Currently I have been trying to simulate laminar CSTR, which is quite close to a (batch) stirred tank reactor.
Same as you, I was successful in 2D but not in 3D. Problem arises when it cannot get initial values.
Currently, I am trying to take things step-by-step. First, now I am trying to solve only the incompressible NS, which is pretty successful for steady-state analysis but not for transient. In transient state, the error that I have been getting consistently is "Failed to find consistent initial value".
I tried to use UMFPACK solver, listening to the advise found in this forum, but it failed after taking about 5 days to run, due to lack of memory.
Right now, I decided to halve my 3D CSTR along the plane of symmetry to speed up the computation. I am still working on it.
How about you? Have you found any solution?
Hi Marco!
Nov 1, 2010, 8:47 a.m. EDT
Hi Marco and Minghui,
I'm dealing with the exact same problem without any success. In particular I am interested to move a permanent magnet above a conducting plate and I have coupled the ALE moving mesh and quasi-static magnetic module. In 2d I can solve the model but in a 3d transient simulation I always end up with the error " failed to find consistent initial value". Although I have solved the model for the stationary case and used the solution as the initial value for time dependent case. Did you finally solve your problem? if so what did you do, I would appreciate if you can help me with my problem.
thanks in advance
Azar
thanks in advance
Azar
