Please Help! COMSOL Automatic Shutdown
For some reason, COMSOL 5.1 automatically shuts down before it finishes computing. I was told a separate window for progress should open up, but it does not. When I look at the progress at the bottom right of the COMSOL window, I notice that he program was just about to run PARADISO before it automatically shuts down. I just recently installed this program on my laptop. (My computer runs on Windows 10, but for some reason, according to the error log below, it says Windows 8).
Could someone please explain to me what the problem is? I have even uninstalled and reinstalled the latest Java version and it still does not work. Please help.
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ILLEGAL_INSTRUCTION (0xc000001d) at pc=0x00007ffa33c6b462, pid=8016, tid=6540
# JRE version: Java(TM) SE Runtime Environment (7.0_75-b13) (build 1.7.0_75-b13)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (24.75-b04 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C 0x00007ffa33c6b462
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x00000267460fa000): JavaThread "pool-10-thread-1" [_thread_in_native, id=6540, stack(0x000000d24c240000,0x000000d24c640000)]
siginfo: ExceptionCode=0xc000001d
Registers:
RAX=0x0000026755fed000, RBX=0x0000026755fee000, RCX=0x000000d24c631fc0, RDX=0x0000026755ec8040
RSP=0x000000d24c631dd0, RBP=0x000000d24c632d50, RSI=0x00007ffa3480b8d8, RDI=0x000000d24c632d90
R8 =0x0000000000000040, R9 =0x0000026755fee000, R10=0x00000000000001f8, R11=0x00000000000000a8
R12=0x0000000000000002, R13=0x000000000000000c, R14=0x0000000000000004, R15=0x0000000000000002
RIP=0x00007ffa33c6b462, EFLAGS=0x0000000000010212
Top of Stack: (sp=0x000000d24c631dd0)
0x000000d24c631dd0: 00000000000000b0 0000000000000000
0x000000d24c631de0: 0000000000000000 00007ffa3345b172
0x000000d24c631df0: 0000000000000000 0000000000000000
0x000000d24c631e00: 408f400000000000 0000000000000000
0x000000d24c631e10: 3f847ae147ae147b 0000000000000000
0x000000d24c631e20: 3f50624dd2f1a9fc 0000000000000000
0x000000d24c631e30: 43f0000000000000 0000000000000000
0x000000d24c631e40: 0000000000000000 0000000000000000
0x000000d24c631e50: 3ff0000000000000 0000000000000000
0x000000d24c631e60: 4024000000000000 0000000000000000
0x000000d24c631e70: 0000000000000000 0000000000000000
0x000000d24c631e80: 3f94b3ae9c28b6aa 0000000000000000
0x000000d24c631e90: 000000d24c631f4e 00007ffa33c6a640
0x000000d24c631ea0: 000000000000000c 0000000000000000
0x000000d24c631eb0: 000002675a386af0 00007ffa338f4e64
0x000000d24c631ec0: 0000000000000010 0000000000000673
Instructions: (pc=0x00007ffa33c6b462)
0x00007ffa33c6b442: 40 0f 0d 4a 60 42 0f 0d 4c 1a 60 42 0f 0d 4c 5a
0x00007ffa33c6b452: 60 42 0f 0d 4c 12 60 c5 7c 28 28 c4 62 7d 19 23
0x00007ffa33c6b462: c4 e3 95 69 c0 c0 c5 7c 28 70 20 c4 e3 8d 69 c9
0x00007ffa33c6b472: c0 c5 7c 28 78 40 c4 e3 85 69 d2 c0 c4 62 7d 19
Register to memory mapping:
RAX=0x0000026755fed000 is an unknown value
RBX=0x0000026755fee000 is an unknown value
RCX=0x000000d24c631fc0 is pointing into the stack for thread: 0x00000267460fa000
RDX=0x0000026755ec8040 is an unknown value
RSP=0x000000d24c631dd0 is pointing into the stack for thread: 0x00000267460fa000
RBP=0x000000d24c632d50 is pointing into the stack for thread: 0x00000267460fa000
RSI=0x00007ffa3480b8d8 is an unknown value
RDI=0x000000d24c632d90 is pointing into the stack for thread: 0x00000267460fa000
R8 =0x0000000000000040 is an unknown value
R9 =0x0000026755fee000 is an unknown value
R10=0x00000000000001f8 is an unknown value
R11=0x00000000000000a8 is an unknown value
R12=0x0000000000000002 is an unknown value
R13=0x000000000000000c is an unknown value
R14=0x0000000000000004 is an unknown value
R15=0x0000000000000002 is an unknown value
Stack: [0x000000d24c240000,0x000000d24c640000], sp=0x000000d24c631dd0, free space=4039k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j com.comsol.nativejni.solver.FlSolver.femStatic(Lcom/comsol/nativejni/server/FlRunnable;Lcom/comsol/nativejni/CPointer;Lcom/comsol/nativejni/CPointer;Lcom/comsol/nativejni/CPointer;Lcom/comsol/nativejni/CPointer;Lcom/comsol/nativejni/CPointer;)V+0
j com.comsol.nativejni.solver.FlSolver.femStatic(Lcom/comsol/nativejni/xmesh/Xmesh;Lcom/comsol/nativejni/util/Prop;Lcom/comsol/nativejni/util/Prop;Lcom/comsol/nativejni/xmesh/Solution;)V+28
j com.comsol.nativemph.c.j.a()V+52
j com.comsol.nativeutil.runnable.f.run()V+122
j com.comsol.solver.solution.SolverBase.a(Lcom/comsol/solver/b;Lcom/comsol/solver/b;Lcom/comsol/model/dbimodel/SavePoint;Lcom/comsol/model/dbimodel/XMeshNative;)V+556
j com.comsol.solver.solution.SolverBase.doExecute(Lcom/comsol/solver/b;)V+167
j com.comsol.solver.SolverOperation.execute(Lcom/comsol/model/dbimodel/SolverSequence;Lcom/comsol/model/dbimodel/SolverFeature;[Lcom/comsol/model/operations/ISolverPropCollector;)V+264
j com.comsol.model.method.SolverSequenceMethod.doRun(Ljava/lang/String;Ljava/lang/String;Z)V+492
j com.comsol.model.internal.impl.SolverSequenceImpl.a(Ljava/lang/String;Ljava/lang/String;Z)V+7
j com.comsol.model.internal.impl.SolverSequenceImpl.k()V+62
j com.comsol.model.internal.impl.SolverSequenceImpl$23.a(Lcom/comsol/model/internal/impl/SolverSequenceImpl;)Ljava/lang/Object;+107
j com.comsol.model.internal.impl.SolverSequenceImpl$23.execute(Lorg/eclipse/emf/ecore/EObject;)Ljava/lang/Object;+5
j com.comsol.model.clientserver.ClientManager$1.call()Ljava/lang/Object;+18
j java.util.concurrent.FutureTask.run()V+42
j java.util.concurrent.ThreadPoolExecutor.runWorker(Ljava/util/concurrent/ThreadPoolExecutor$Worker;)V+95
j java.util.concurrent.ThreadPoolExecutor$Worker.run()V+5
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x0000026746566000 JavaThread "pool-11-thread-1" [_thread_blocked, id=5504, stack(0x000000d254540000,0x000000d254940000)]
0x0000026746566800 JavaThread "pool-4-thread-1" [_thread_blocked, id=7052, stack(0x000000d252bc0000,0x000000d252fc0000)]
0x0000026746565000 JavaThread "pool-5-thread-2" [_thread_blocked, id=2088, stack(0x000000d251b80000,0x000000d251f80000)]
0x00000267460fd000 JavaThread "pool-2-thread-1" [_thread_blocked, id=7968, stack(0x000000d250b00000,0x000000d250f00000)]
0x00000267460fb800 JavaThread "[ThreadPool Manager] - Idle Thread" daemon [_thread_blocked, id=1952, stack(0x000000d24f280000,0x000000d24f680000)]
=>0x00000267460fa000 JavaThread "pool-10-thread-1" [_thread_in_native, id=6540, stack(0x000000d24c240000,0x000000d24c640000)]
0x00000267460f8800 JavaThread "Worker-1" [_thread_blocked, id=1804, stack(0x000000d24be40000,0x000000d24c240000)]
0x00000267460fa800 JavaThread "pool-1-thread-1" [_thread_blocked, id=5392, stack(0x000000d24ae00000,0x000000d24b200000)]
0x00000267460fd800 JavaThread "pool-5-thread-1" [_thread_blocked, id=8088, stack(0x000000d24aa00000,0x000000d24ae00000)]
0x00000267460f7000 JavaThread "Thread-5" daemon [_thread_in_native, id=5664, stack(0x000000d24a600000,0x000000d24aa00000)]
0x00000267460f7800 JavaThread "clientcommunicator" daemon [_thread_blocked, id=2780, stack(0x000000d24a200000,0x000000d24a600000)]
0x00000267460fc000 JavaThread "Worker-0" [_thread_blocked, id=5036, stack(0x000000d249600000,0x000000d249a00000)]
0x000002674650e800 JavaThread "Worker-JM" [_thread_blocked, id=7640, stack(0x000000d248a00000,0x000000d248e00000)]
0x0000026745af0000 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=7452, stack(0x000000d248600000,0x000000d248a00000)]
0x0000026745ade800 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=5696, stack(0x000000d247e00000,0x000000d248200000)]
0x000002674597e000 JavaThread "Refresh Thread: Equinox Container: 60dd3cce-8c10-0016-1acf-cc909971029b" daemon [_thread_blocked, id=8144, stack(0x000000d247a00000,0x000000d247e00000)]
0x000002674597f000 JavaThread "Start Level: Equinox Container: 60dd3cce-8c10-0016-1acf-cc909971029b" daemon [_thread_blocked, id=7836, stack(0x000000d247600000,0x000000d247a00000)]
0x0000026745936800 JavaThread "Framework Event Dispatcher: Equinox Container: 60dd3cce-8c10-0016-1acf-cc909971029b" daemon [_thread_blocked, id=5448, stack(0x000000d247200000,0x000000d247600000)]
0x000002673e992800 JavaThread "Active Thread: Equinox Container: 60dd3cce-8c10-0016-1acf-cc909971029b" [_thread_blocked, id=924, stack(0x000000d246e00000,0x000000d247200000)]
0x000002673d6d3800 JavaThread "Service Thread" daemon [_thread_blocked, id=3420, stack(0x000000d246600000,0x000000d246a00000)]
0x000002673d6c7800 JavaThread "C2 CompilerThread1" daemon [_thread_in_native, id=7236, stack(0x000000d246200000,0x000000d246600000)]
0x000002673d10a800 JavaThread "C2 CompilerThread0" daemon [_thread_in_native, id=4464, stack(0x000000d245e00000,0x000000d246200000)]
0x000002673d782800 JavaThread "Attach Listener" daemon [_thread_blocked, id=7008, stack(0x000000d245a00000,0x000000d245e00000)]
0x000002673e6b3800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=6288, stack(0x000000d245600000,0x000000d245a00000)]
0x000002673e6dc000 JavaThread "Finalizer" daemon [_thread_blocked, id=7208, stack(0x000000d245200000,0x000000d245600000)]
0x000002673e6db800 JavaThread "Reference Handler" daemon [_thread_blocked, id=7076, stack(0x000000d244e00000,0x000000d245200000)]
0x000002673d697800 JavaThread "main" [_thread_in_native, id=6120, stack(0x000000d23e200000,0x000000d23e600000)]
Other Threads:
0x000002673d690800 VMThread [stack: 0x000000d244a00000,0x000000d244e00000] [id=6708]
0x000002673d6d8000 WatcherThread [stack: 0x000000d246a00000,0x000000d246e00000] [id=6724]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
PSYoungGen total 98816K, used 33764K [0x00000000eaa80000, 0x00000000f4c80000, 0x0000000100000000)
eden space 94208K, 35% used [0x00000000eaa80000,0x00000000ecb79010,0x00000000f0680000)
from space 4608K, 0% used [0x00000000f0680000,0x00000000f0680000,0x00000000f0b00000)
to space 35840K, 0% used [0x00000000f2980000,0x00000000f2980000,0x00000000f4c80000)
ParOldGen total 121344K, used 62832K [0x00000000c0000000, 0x00000000c7680000, 0x00000000eaa80000)
object space 121344K, 51% used [0x00000000c0000000,0x00000000c3d5c108,0x00000000c7680000)
PSPermGen total 130048K, used 83828K [0x00000000b0000000, 0x00000000b7f00000, 0x00000000c0000000)
object space 130048K, 64% used [0x00000000b0000000,0x00000000b51dd3e8,0x00000000b7f00000)
Card table byte_map: [0x00000267419b0000,0x0000026741c40000] byte_map_base: 0x0000026741430000
Polling page: 0x000002673d240000
Code Cache [0x000002673e9b0000, 0x000002673f1a0000, 0x00000267419b0000)
total_blobs=2862 nmethods=2198 adapters=615 free_code_cache=41198Kb largest_free_block=42061760
Compilation events (10 events):
Event: 106.220 Thread 0x000002673d6c7800 nmethod 2507 0x000002673f17e910 code [0x000002673f17eb00, 0x000002673f17f008]
Event: 106.220 Thread 0x000002673d6c7800 2508 com.comsol.model.selections.SelectionMethod::geom (44 bytes)
Event: 106.225 Thread 0x000002673d6c7800 nmethod 2508 0x000002673f177610 code [0x000002673f1777a0, 0x000002673f177988]
Event: 106.225 Thread 0x000002673d6c7800 2509 com.comsol.model.internal.impl.ModelImpl::getGeom (42 bytes)
Event: 106.290 Thread 0x000002673d6c7800 nmethod 2509 0x000002673f187610 code [0x000002673f187980, 0x000002673f188ac8]
Event: 106.291 Thread 0x000002673d6c7800 2510 com.comsol.util.classes.af::<init> (17 bytes)
Event: 106.293 Thread 0x000002673d6c7800 nmethod 2510 0x000002673eef7a10 code [0x000002673eef7b60, 0x000002673eef7c78]
Event: 106.293 Thread 0x000002673d6c7800 2511 java.util.HashSet::add (20 bytes)
Event: 106.294 Thread 0x000002673d6c7800 nmethod 2511 0x000002673eef76d0 code [0x000002673eef7820, 0x000002673eef78e8]
Event: 106.295 Thread 0x000002673d6c7800 2512 com.comsol.model.method.UnitMethod::symbol (119 bytes)
GC Heap History (10 events):
Event: 94.948 GC heap before
{Heap before GC invocations=44 (full 4):
PSYoungGen total 123904K, used 81787K [0x00000000eaa80000, 0x00000000f5400000, 0x0000000100000000)
eden space 80384K, 100% used [0x00000000eaa80000,0x00000000ef900000,0x00000000ef900000)
from space 43520K, 3% used [0x00000000ef900000,0x00000000efa5ecb0,0x00000000f2380000)
to space 42496K, 0% used [0x00000000f2a80000,0x00000000f2a80000,0x00000000f5400000)
ParOldGen total 121344K, used 61557K [0x00000000c0000000, 0x00000000c7680000, 0x00000000eaa80000)
object space 121344K, 50% used [0x00000000c0000000,0x00000000c3c1d5d0,0x00000000c7680000)
PSPermGen total 126464K, used 82249K [0x00000000b0000000, 0x00000000b7b80000, 0x00000000c0000000)
object space 126464K, 65% used [0x00000000b0000000,0x00000000b5052488,0x00000000b7b80000)
Event: 94.975 GC heap after
Heap after GC invocations=44 (full 4):
PSYoungGen total 126976K, used 4866K [0x00000000eaa80000, 0x00000000f5080000, 0x0000000100000000)
eden space 88064K, 0% used [0x00000000eaa80000,0x00000000eaa80000,0x00000000f0080000)
from space 38912K, 12% used [0x00000000f2a80000,0x00000000f2f40850,0x00000000f5080000)
to space 40960K, 0% used [0x00000000f0080000,0x00000000f0080000,0x00000000f2880000)
Event: 98.147 GC heap before
{Heap before GC invocations=45 (full 4):
PSYoungGen total 126976K, used 92930K [0x00000000eaa80000, 0x00000000f5080000, 0x0000000100000000)
eden space 88064K, 100% used [0x00000000eaa80000,0x00000000f0080000,0x00000000f0080000)
PSPermGen total 126464K, used 82374K [0x00000000b0000000, 0x00000000b7b80000, 0x00000000c0000000)
object space 126464K, 65% used [0x00000000b0000000,0x00000000b5071aa8,0x00000000b7b80000)
Event: 98.172 GC heap after
Heap after GC invocations=45 (full 4):
PSYoungGen total 129024K, used 3523K [0x00000000eaa80000, 0x00000000f5500000, 0x0000000100000000)
from space 40960K, 8% used [0x00000000f0080000,0x00000000f03f0db8,0x00000000f2880000)
to space 39424K, 0% used [0x00000000f2e80000,0x00000000f2e80000,0x00000000f5500000)
Event: 100.943 GC heap before
{Heap before GC invocations=46 (full 4):
PSYoungGen total 129024K, used 91587K [0x00000000eaa80000, 0x00000000f5500000, 0x0000000100000000)
PSPermGen total 126464K, used 83147K [0x00000000b0000000, 0x00000000b7b80000, 0x00000000c0000000)
object space 126464K, 65% used [0x00000000b0000000,0x00000000b5132da8,0x00000000b7b80000)
Event: 100.967 GC heap after
Heap after GC invocations=46 (full 4):
PSYoungGen total 128000K, used 5638K [0x00000000eaa80000, 0x00000000f4f80000, 0x0000000100000000)
eden space 94208K, 0% used [0x00000000eaa80000,0x00000000eaa80000,0x00000000f0680000)
from space 33792K, 16% used [0x00000000f2e80000,0x00000000f3401ad8,0x00000000f4f80000)
to space 37376K, 0% used [0x00000000f0680000,0x00000000f0680000,0x00000000f2b00000)
Event: 102.108 GC heap before
{Heap before GC invocations=47 (full 4):
PSYoungGen total 128000K, used 32024K [0x00000000eaa80000, 0x00000000f4f80000, 0x0000000100000000)
eden space 94208K, 28% used [0x00000000eaa80000,0x00000000ec444780,0x00000000f0680000)
PSPermGen total 126464K, used 83530K [0x00000000b0000000, 0x00000000b7b80000, 0x00000000c0000000)
object space 126464K, 66% used [0x00000000b0000000,0x00000000b5192950,0x00000000b7b80000)
Event: 102.130 GC heap after
Heap after GC invocations=47 (full 4):
PSYoungGen total 98816K, used 4519K [0x00000000eaa80000, 0x00000000f4c80000, 0x0000000100000000)
from space 4608K, 98% used [0x00000000f0680000,0x00000000f0ae9c40,0x00000000f0b00000)
Event: 102.130 GC heap before
{Heap before GC invocations=48 (full 5):
Event: 103.331 GC heap after
Heap after GC invocations=48 (full 5):
PSYoungGen total 98816K, used 0K [0x00000000eaa80000, 0x00000000f4c80000, 0x0000000100000000)
PSPermGen total 130048K, used 83519K [0x00000000b0000000, 0x00000000b7f00000, 0x00000000c0000000)
object space 130048K, 64% used [0x00000000b0000000,0x00000000b518fe20,0x00000000b7f00000)
Deoptimization events (10 events):
Event: 101.801 Thread 0x00000267460fa000 Uncommon trap: reason=class_check action=maybe_recompile pc=0x000002673ebce174 method=org.eclipse.emf.common.util.BasicEMap.containsKey(Ljava/lang/Object;)Z @ 8
Event: 103.367 Thread 0x00000267460fa000 Uncommon trap: reason=null_check action=make_not_entrant pc=0x000002673ebae33c method=org.eclipse.emf.common.util.BasicEList.assign(ILjava/lang/Object;)Ljava/lang/Object; @ 6
Event: 103.370 Thread 0x00000267460fa000 Uncommon trap: reason=unreached action=reinterpret pc=0x000002673eca7b98 method=org.eclipse.emf.ecore.impl.EStructuralFeatureImpl$InternalSettingDelegateSingleData.dynamicSet(Lorg/eclipse/emf/ecore/InternalEObject;Lorg/eclipse/emf/ecore/EStructuralFeature$yV‘‡òY@
Event: 103.783 Thread 0x00000267460fa000 Uncommon trap: reason=class_check action=maybe_recompile pc=0x000002673eb1226c method=org.eclipse.emf.common.util.BasicEList.addAllUnique(Ljava/util/Collection;)Z @ 1
Event: 103.806 Thread 0x00000267460fa000 Uncommon trap: reason=class_check action=maybe_recompile pc=0x000002673edf0d74 method=org.eclipse.emf.common.util.BasicEMap.ensureEntryDataExists()V @ 37
Event: 103.806 Thread 0x00000267460fa000 Uncommon trap: reason=class_check action=maybe_recompile pc=0x000002673ebce174 method=org.eclipse.emf.common.util.BasicEMap.containsKey(Ljava/lang/Object;)Z @ 8
Event: 104.004 Thread 0x00000267460fa000 Uncommon trap: reason=class_check action=maybe_recompile pc=0x000002673ebce174 method=org.eclipse.emf.common.util.BasicEMap.containsKey(Ljava/lang/Object;)Z @ 8
Event: 104.803 Thread 0x00000267460fa000 Uncommon trap: reason=null_check action=make_not_entrant pc=0x000002673ec40c38 method=org.eclipse.emf.common.util.BasicEList.assign(ILjava/lang/Object;)Ljava/lang/Object; @ 6
Event: 105.072 Thread 0x0000026746566800 Uncommon trap: reason=unreached action=reinterpret pc=0x000002673f00fe70 method=com.comsol.model.internal.impl.ModelImpl.getModelEventManager()Lcom/comsol/model/internal/events/ModelEventManager; @ 6
Event: 105.072 Thread 0x0000026746566800 Uncommon trap: reason=null_check action=make_not_entrant pc=0x000002673ef8e7ac method=com.comsol.model.internal.impl.ModelImpl.getGeomGen()Lcom/comsol/model/internal/GeomList; @ 8
Internal exceptions (10 events):
Event: 101.774 Thread 0x00000267460fa000 Threw 0x00000000ec1f9a88 at C:\re\jdk7u75\1940\hotspot\src\share\vm\prims\jvm.cpp:1281
Event: 103.367 Thread 0x00000267460fa000 Implicit null exception at 0x000002673ebae0f1 to 0x000002673ebae331
Event: 103.790 Thread 0x00000267460fa000 Threw 0x00000000eb174a28 at C:\re\jdk7u75\1940\hotspot\src\share\vm\prims\jvm.cpp:1281
Event: 103.790 Thread 0x00000267460fa000 Threw 0x00000000eb175488 at C:\re\jdk7u75\1940\hotspot\src\share\vm\prims\jvm.cpp:1281
Event: 103.790 Thread 0x00000267460fa000 Threw 0x00000000eb176010 at C:\re\jdk7u75\1940\hotspot\src\share\vm\prims\jvm.cpp:1281
Event: 103.790 Thread 0x00000267460fa000 Threw 0x00000000eb176a70 at C:\re\jdk7u75\1940\hotspot\src\share\vm\prims\jvm.cpp:1281
Event: 103.805 Thread 0x00000267460fa000 Threw 0x00000000eb1803d0 at C:\re\jdk7u75\1940\hotspot\src\share\vm\prims\jvm.cpp:1281
Event: 103.805 Thread 0x00000267460fa000 Threw 0x00000000eb180e30 at C:\re\jdk7u75\1940\hotspot\src\share\vm\prims\jvm.cpp:1281
Event: 104.803 Thread 0x00000267460fa000 Implicit null exception at 0x000002673ec40b21 to 0x000002673ec40c2d
Event: 105.072 Thread 0x0000026746566800 Implicit null exception at 0x000002673ef8e470 to 0x000002673ef8e7a1
Events (10 events):
Event: 105.072 Thread 0x0000026746566800 DEOPT PACKING pc=0x000002673ef8e7ac sp=0x000000d252fbe660
Event: 105.072 Thread 0x0000026746566800 DEOPT UNPACKING pc=0x000002673e9e90ac sp=0x000000d252fbe638 mode 2
Event: 105.076 loading class 0x000002675551f360
Event: 105.076 loading class 0x000002675551f360 done
Event: 105.077 loading class 0x000002675551fcc0
Event: 105.077 loading class 0x000002675551fcc0 done
Event: 105.086 Thread 0x000002673d6c7800 flushing nmethod 0x000002673eef5d50
Event: 105.087 Thread 0x000002673d6c7800 flushing nmethod 0x000002673eefbcd0
Event: 105.092 Thread 0x000002673d6c7800 flushing nmethod 0x000002673ef10e50
Event: 105.092 Thread 0x000002673d6c7800 flushing nmethod 0x000002673ef52cd0
Dynamic libraries:
0x0000026720f80000 - 0x0000026720fa2000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\bin\win64\comsol.exe
0x00007ffa677f0000 - 0x00007ffa679b1000 C:\WINDOWS\SYSTEM32\ntdll.dll
0x00007ffa53ef0000 - 0x00007ffa53f58000 C:\WINDOWS\SYSTEM32\MSCOREE.DLL
0x00007ffa65f10000 - 0x00007ffa65fbd000 C:\WINDOWS\system32\KERNEL32.dll
0x00007ffa64670000 - 0x00007ffa64858000 C:\WINDOWS\system32\KERNELBASE.dll
0x00007ffa65a30000 - 0x00007ffa65ad7000 C:\WINDOWS\system32\ADVAPI32.dll
0x00007ffa67640000 - 0x00007ffa676dd000 C:\WINDOWS\system32\msvcrt.dll
0x00007ffa651f0000 - 0x00007ffa6524b000 C:\WINDOWS\system32\sechost.dll
0x00007ffa65450000 - 0x00007ffa6556c000 C:\WINDOWS\system32\RPCRT4.dll
0x00007ffa4cd90000 - 0x00007ffa4ce28000 C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll
0x00007ffa65fc0000 - 0x00007ffa66012000 C:\WINDOWS\system32\SHLWAPI.dll
0x00007ffa65ae0000 - 0x00007ffa65d5d000 C:\WINDOWS\system32\combase.dll
0x00007ffa64600000 - 0x00007ffa6466a000 C:\WINDOWS\system32\bcryptPrimitives.dll
0x00007ffa652c0000 - 0x00007ffa65446000 C:\WINDOWS\system32\GDI32.dll
0x00007ffa658d0000 - 0x00007ffa65a26000 C:\WINDOWS\system32\USER32.dll
0x00007ffa65ed0000 - 0x00007ffa65f0b000 C:\WINDOWS\system32\IMM32.DLL
0x00007ffa63e70000 - 0x00007ffa63e7f000 C:\WINDOWS\system32\kernel.appcore.dll
0x00007ffa60440000 - 0x00007ffa6044a000 C:\WINDOWS\SYSTEM32\VERSION.dll
0x00007ffa44320000 - 0x00007ffa44cb0000 C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll
0x00007ffa490d0000 - 0x00007ffa491c7000 C:\WINDOWS\SYSTEM32\MSVCR120_CLR0400.dll
0x00007ffa42e50000 - 0x00007ffa44314000 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\mscorlib\2c5440b166ece2da7d6cc4031a72127c\mscorlib.ni.dll
0x00007ffa65d80000 - 0x00007ffa65ec3000 C:\WINDOWS\system32\ole32.dll
0x00007ffa62790000 - 0x00007ffa62826000 C:\WINDOWS\system32\uxtheme.dll
0x00007ffa53990000 - 0x00007ffa53a33000 C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll
0x00007ffa65570000 - 0x00007ffa65631000 C:\WINDOWS\system32\OLEAUT32.dll
0x00007ffa4a490000 - 0x00007ffa4a595000 C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrjit.dll
0x00007ffa66020000 - 0x00007ffa6757c000 C:\WINDOWS\system32\shell32.dll
0x00007ffa64af0000 - 0x00007ffa64b33000 C:\WINDOWS\system32\cfgmgr32.dll
0x00007ffa63f90000 - 0x00007ffa645d5000 C:\WINDOWS\system32\windows.storage.dll
0x00007ffa64a30000 - 0x00007ffa64ae5000 C:\WINDOWS\system32\shcore.dll
0x00007ffa63e10000 - 0x00007ffa63e5b000 C:\WINDOWS\system32\powrprof.dll
0x00007ffa63e80000 - 0x00007ffa63e94000 C:\WINDOWS\system32\profapi.dll
0x00007ffa42280000 - 0x00007ffa42e50000 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System\c8cc15551e0d7f24a438dc13744f7113\System.ni.dll
0x00007ffa67630000 - 0x00007ffa67638000 C:\WINDOWS\system32\psapi.dll
0x00007ffa637f0000 - 0x00007ffa63807000 C:\WINDOWS\SYSTEM32\CRYPTSP.dll
0x00007ffa63480000 - 0x00007ffa634b4000 C:\WINDOWS\system32\rsaenh.dll
0x00007ffa63d40000 - 0x00007ffa63d69000 C:\WINDOWS\SYSTEM32\bcrypt.dll
0x00007ffa63910000 - 0x00007ffa6391b000 C:\WINDOWS\SYSTEM32\CRYPTBASE.dll
0x00007ffa411b0000 - 0x00007ffa41b35000 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Core\48a76f4b200d6ee3432997953c7d37e9\System.Core.ni.dll
0x00007ffa45e00000 - 0x00007ffa462d4000 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\WindowsBase\e22c1fb783b3ae4242e720fc72c3012e\WindowsBase.ni.dll
0x00007ffa40450000 - 0x00007ffa411ac000 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PresentationCore\9236444da3be0cab1b4a4e9ce26a4148\PresentationCore.ni.dll
0x00007ffa3b880000 - 0x00007ffa3ce67000 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\Presentatio5ae0f00f#\6802bed4bd856378a76607ce60d3e970\PresentationFramework.ni.dll
0x00007ffa4a240000 - 0x00007ffa4a487000 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Xaml\b4f86255aa062df99531ccbe82706b10\System.Xaml.ni.dll
0x00007ffa5c370000 - 0x00007ffa5c5d0000 C:\WINDOWS\SYSTEM32\dwrite.dll
0x00007ffa458e0000 - 0x00007ffa45aef000 C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\wpfgfx_v0400.dll
0x00007ffa4a130000 - 0x00007ffa4a235000 C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\PresentationNative_v0400.dll
0x00007ffa61840000 - 0x00007ffa61862000 C:\WINDOWS\system32\dwmapi.dll
0x00007ffa53eb0000 - 0x00007ffa53ee8000 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\UIAutomationTypes\54bd0902079650e97db628bcd1156c2d\UIAutomationTypes.ni.dll
0x00007ffa65090000 - 0x00007ffa651ea000 C:\WINDOWS\system32\MSCTF.dll
0x00007ffa4a000000 - 0x00007ffa4a09b000 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\Presentatioaec034ca#\bfe569174c9e4bc9f80f3ee6a06113a6\PresentationFramework.Aero2.ni.dll
0x00007ffa42060000 - 0x00007ffa42278000 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Wind412bbddf#\adfbe1b4165a76ebcea3c2916e7e6723\System.Windows.Controls.Ribbon.ni.dll
0x00007ffa5a250000 - 0x00007ffa5a264000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\bin\win64\JavaBridge.dll
0x00000000564b0000 - 0x0000000056548000 C:\WINDOWS\SYSTEM32\MSVCP100.dll
0x0000000056550000 - 0x0000000056622000 C:\WINDOWS\SYSTEM32\MSVCR100.dll
0x00007ffa606a0000 - 0x00007ffa60851000 C:\WINDOWS\SYSTEM32\WindowsCodecs.dll
0x00007ffa5a1e0000 - 0x00007ffa5a1f5000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\bin\win64\NativeUnpack.dll
0x00007ffa54aa0000 - 0x00007ffa54ab3000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\bin\win64\cstextrenderer_wpf.dll
0x00007ffa49f30000 - 0x00007ffa49ffd000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\lib\win64\cstextrenderer.dll
0x00007ffa46740000 - 0x00007ffa46891000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\lib\win64\csutil.dll
0x0000000180000000 - 0x0000000180148000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\bin\win64\libiomp5md.dll
0x00007ffa44cc0000 - 0x00007ffa44e79000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\lib\win64\ipv4\csnutil.dll
0x00007ffa645e0000 - 0x00007ffa645f7000 C:\WINDOWS\system32\NETAPI32.dll
0x00007ffa676e0000 - 0x00007ffa677eb000 C:\WINDOWS\system32\COMDLG32.dll
0x00007ffa63f00000 - 0x00007ffa63f86000 C:\WINDOWS\system32\FirewallAPI.dll
0x00007ffa64bf0000 - 0x00007ffa64c5b000 C:\WINDOWS\system32\WS2_32.dll
0x00007ffa55100000 - 0x00007ffa551aa000 C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.10586.0_none_396e892957c7fb25\COMCTL32.dll
0x00007ffa63ea0000 - 0x00007ffa63ef5000 C:\WINDOWS\system32\WINTRUST.dll
0x00007ffa4d860000 - 0x00007ffa4d869000 C:\WINDOWS\SYSTEM32\WSOCK32.dll
0x00007ffa63e60000 - 0x00007ffa63e70000 C:\WINDOWS\system32\MSASN1.dll
0x00007ffa64860000 - 0x00007ffa64a27000 C:\WINDOWS\system32\CRYPT32.dll
0x00007ffa5bbb0000 - 0x00007ffa5bbbc000 C:\WINDOWS\SYSTEM32\DAVHLPR.DLL
0x00007ffa62b90000 - 0x00007ffa62bc2000 C:\WINDOWS\system32\fwbase.dll
0x00007ffa61eb0000 - 0x00007ffa61ec3000 C:\WINDOWS\SYSTEM32\WtsApi32.dll
0x00007ffa630b0000 - 0x00007ffa63106000 C:\WINDOWS\SYSTEM32\WINSTA.dll
0x00007ffa41e50000 - 0x00007ffa42060000 C:\WINDOWS\SYSTEM32\d3d9.dll
0x00007ffa60450000 - 0x00007ffa605b2000 C:\WINDOWS\SYSTEM32\aticfx64.dll
0x00007ffa62590000 - 0x00007ffa625b3000 C:\WINDOWS\SYSTEM32\WINMM.dll
0x00007ffa62560000 - 0x00007ffa6258c000 C:\WINDOWS\SYSTEM32\WINMMBASE.dll
0x00007ffa53e80000 - 0x00007ffa53ea1000 C:\WINDOWS\SYSTEM32\atiu9p64.dll
0x00007ffa3fbf0000 - 0x00007ffa4044b000 C:\WINDOWS\SYSTEM32\atiumd64.dll
0x00000000569b0000 - 0x0000000057236000 C:\WINDOWS\SYSTEM32\atiumd6a.dll
0x00007ffa477a0000 - 0x00007ffa478c0000 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Configuration\5a1f79b36805ce004fd92d166d7d5c66\System.Configuration.ni.dll
0x00007ffa3f350000 - 0x00007ffa3fbe2000 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Xml\feae4ec2ac506cb2f089c5aa0c2a0751\System.Xml.ni.dll
0x00007ffa67580000 - 0x00007ffa67627000 C:\WINDOWS\system32\clbcatq.dll
0x00007ffa54950000 - 0x00007ffa54968000 C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\PenIMC.dll
0x00007ffa53c20000 - 0x00007ffa53c68000 C:\WINDOWS\System32\wisp.dll
0x00007ffa54040000 - 0x00007ffa54050000 C:\WINDOWS\SYSTEM32\atlthunk.dll
0x00007ffa54860000 - 0x00007ffa5487c000 C:\Program Files\Common Files\Microsoft Shared\Ink\tpcps.dll
0x00007ffa51560000 - 0x00007ffa515aa000 C:\WINDOWS\system32\dataexchange.dll
0x00007ffa61ed0000 - 0x00007ffa61fb3000 C:\WINDOWS\system32\dcomp.dll
0x00007ffa61590000 - 0x00007ffa61838000 C:\WINDOWS\system32\d3d11.dll
0x00007ffa614e0000 - 0x00007ffa61583000 C:\WINDOWS\system32\dxgi.dll
0x00007ffa62930000 - 0x00007ffa62a30000 C:\WINDOWS\system32\twinapi.appcore.dll
0x00007ffa53be0000 - 0x00007ffa53bfc000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\bin\win64\csgraphics_wpf_common.dll
0x00007ffa3e690000 - 0x00007ffa3e866000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\lib\win64\csgraphics_scene_common.dll
0x00007ffa53a50000 - 0x00007ffa53ad7000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\lib\win64\csdatacarrier.dll
0x00007ffa5aa60000 - 0x00007ffa5ac17000 C:\WINDOWS\SYSTEM32\urlmon.dll
0x00007ffa5cc70000 - 0x00007ffa5cff3000 C:\WINDOWS\SYSTEM32\iertutil.dll
0x00007ffa48f70000 - 0x00007ffa49001000 C:\WINDOWS\SYSTEM32\mscms.dll
0x00007ffa635d0000 - 0x00007ffa635ef000 C:\WINDOWS\SYSTEM32\USERENV.dll
0x00007ffa53940000 - 0x00007ffa5398a000 C:\WINDOWS\SYSTEM32\WindowsCodecsExt.dll
0x00007ffa533b0000 - 0x00007ffa53403000 C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\Presentatiod51afaa5#\815a04cc479563ee31496b2a65bbfafb\PresentationFramework.Classic.ni.dll
0x00007ffa63af0000 - 0x00007ffa63b1d000 C:\WINDOWS\SYSTEM32\SspiCli.dll
0x00007ffa51e80000 - 0x00007ffa51ed2000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\bin\win64\csgraphics_wpf_dx9.dll
0x00007ffa3de50000 - 0x00007ffa3e0a6000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\lib\win64\csgraphics_dx9.dll
0x00007ffa3b300000 - 0x00007ffa3b87f000 C:\WINDOWS\SYSTEM32\d3dx9_40.dll
0x00007ffa3dbd0000 - 0x00007ffa3de4b000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\lib\win64\cs3d_dx9.dll
0x00007ffa457e0000 - 0x00007ffa458e0000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\ext\graphicsmagick\win64\CORE_RL_magick_.dll
0x00007ffa53bc0000 - 0x00007ffa53bd7000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\ext\graphicsmagick\win64\CORE_RL_zlib_.dll
0x00007ffa53920000 - 0x00007ffa53934000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\ext\graphicsmagick\win64\CORE_RL_bzlib_.dll
0x0000000055cd0000 - 0x00000000564a4000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\java\win64\jre\bin\server\jvm.dll
0x0000000055cc0000 - 0x0000000055ccf000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\java\win64\jre\bin\verify.dll
0x0000000055c90000 - 0x0000000055cb8000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\java\win64\jre\bin\java.dll
0x0000000055c70000 - 0x0000000055c85000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\java\win64\jre\bin\zip.dll
0x0000000055c50000 - 0x0000000055c69000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\java\win64\jre\bin\net.dll
0x00007ffa63740000 - 0x00007ffa6379c000 C:\WINDOWS\system32\mswsock.dll
0x00007ffa5bad0000 - 0x00007ffa5bb08000 C:\WINDOWS\SYSTEM32\IPHLPAPI.DLL
0x00007ffa65640000 - 0x00007ffa65648000 C:\WINDOWS\system32\NSI.dll
0x00007ffa5b9c0000 - 0x00007ffa5b9d6000 C:\WINDOWS\SYSTEM32\dhcpcsvc6.DLL
0x00007ffa5b960000 - 0x00007ffa5b97a000 C:\WINDOWS\SYSTEM32\dhcpcsvc.DLL
0x0000000055c30000 - 0x0000000055c41000 C:\Program Files\COMSOL\COMSOL51\Multiphysics\java\win64\jre\bin\nio.dll
0x00007ffa54210000 - 0x00007ffa54226000 C:\WINDOWS\system32\napinsp.dll
0x00007ffa556c0000 - 0x00007ffa556da000 C:\WINDOWS\system32\pnrpnsp.dll
0x00007ffa61370000 - 0x00007ffa61388000 C:\WINDOWS\system32\NLAapi.dll
0x00007ffa62880000 - 0x00007ffa6292a000 C:\WINDOWS\SYSTEM32\DNSAPI.dll
0x00007ffa55de0000 - 0x00007ffa55ded000 C:\WINDOWS\System32\winrnr.dll
0x00007ffa55e30000 - 0x00007ffa55e45000 C:\WINDOWS\System32\wshbth.dll
0x00007ffa598a0000 - 0x00007ffa598aa000 C:\Windows\System32\rasadhlp.dll
VM Arguments:
jvm_args: -Duser.home=C:\Users\User -Dinstall.dir=C:\Program Files\COMSOL\COMSOL51\Multiphysics -Djava.security.manager= -Djava.security.policy=C:\Program Files\COMSOL\COMSOL51\Multiphysics/bin/win64/comsol.policy -Xss4m -Xms40m -Xmx1024m -XX:MaxPermSize=256m -XX:ParallelGCThreads=4
java_command: <unknown>
Launcher Type: generic
Environment Variables:
PATH=C:\Program Files\COMSOL\COMSOL51\Multiphysics\ext\graphicsmagick\win64\;;C:\Program Files\COMSOL\COMSOL51\Multiphysics\lib\win64\ipv4;C:\Program Files\COMSOL\COMSOL51\Multiphysics\bin\win64;C:\Program Files\COMSOL\COMSOL51\Multiphysics\lib\win64;C:\Program Files\COMSOL\COMSOL51\Multiphysics\ext\cadimport\win64;C:\Program Files\COMSOL\COMSOL51\Multiphysics/ext/graphicsmagick/win64;C:\Program Files\COMSOL\COMSOL51\Multiphysics\lib\win64;C:\Program Files\COMSOL\COMSOL51\Multiphysics\lib\win64\ipv4;C:\Program Files\COMSOL\COMSOL51\Multiphysics\bin\win64;C:\ProgramData\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\
USERNAME=User
OS=Windows_NT
PROCESSOR_IDENTIFIER=AMD64 Family 22 Model 48 Stepping 1, AuthenticAMD
--------------- S Y S T E M ---------------
OS: Windows 8 , 64 bit Build 9200
CPU:total 4 (4 cores per cpu, 1 threads per core) family 22 model 48 stepping 1, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, aes, mmxext, 3dnowpref, lzcnt, sse4a, tsc, tscinvbit, tscinv
Memory: 4k page, physical 7272100k(4735352k free), swap 8451748k(5763760k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (24.75-b04) for windows-amd64 JRE (1.7.0_75-b13), built on Dec 18 2014 17:15:01 by "java_re" with unknown MS VC++:1600
time: Mon May 02 10:41:06 2016
elapsed time: 106 seconds
11 Replies Last Post May 9, 2016, 12:23 a.m. EDT
Jim Freels mechanical side of nuclear engineering, multiphysics analysis, COMSOL specialist
Posted: 8 years ago May 3, 2016, 8:58 p.m. EDT
I am just going to guess at the problem.
First, I do know that it is not necessary to be concerned about installing a different version of Java. COMSOL comes with Java installed within itself, and it is set up to use that version of Java by default. The Java error messages you see are generated by COMSOL package as a whole, and help to determine the cause of the error you are getting. So, unless you override the default Java with a command line switch and tell COMSOL to use an external version of Java you have installed, you are wasting your time to install another version of Java.
Usually, you can find the cause of the error right at the very beginning of your Java dump. Your Java dumps says early on "EXCEPTION_ILLEGAL_INSTRUCTION (0xc000001d) at pc=0x00007ffa33c6b462, pid=8016, tid=6540". This strange message doesn't really tell you much, so I am going to guess that you have exceeded your memory limit of the machine.
I base this guess by the fact that you are using a Direct solver, PARDISO, which uses the most memory of all solvers in the package. So, let's proceed to try to figure out the problem.
1. Try to reduce the problem size to a bare minimum by using the coarsest mesh you can create for the problem. Replace your existing mesh with the coarsest mesh you can devise.
2. Resolve, and see if the problem persists.
3. If it does persist, try to replace the direct solver of all the variables, with a segregated solver of groups of variables. Note: you have not mentioned what you are solving.
4. If that persists, try to replace the direct solver with iterative solvers which use much less memory.
You see the pattern ?
I am just going to guess at the problem. First, I do know that it is not necessary to be concerned about installing a different version of Java. COMSOL comes with Java installed within itself, and it is set up to use that version of Java by default. The Java error messages you see are generated by COMSOL package as a whole, and help to determine the cause of the error you are getting. So, unless you override the default Java with a command line switch and tell COMSOL to use an external version of Java you have installed, you are wasting your time to install another version of Java. Usually, you can find the cause of the error right at the very beginning of your Java dump. Your Java dumps says early on "EXCEPTION_ILLEGAL_INSTRUCTION (0xc000001d) at pc=0x00007ffa33c6b462, pid=8016, tid=6540". This strange message doesn't really tell you much, so I am going to guess that you have exceeded your memory limit of the machine. I base this guess by the fact that you are using a Direct solver, PARDISO, which uses the most memory of all solvers in the package. So, let's proceed to try to figure out the problem. 1. Try to reduce the problem size to a bare minimum by using the coarsest mesh you can create for the problem. Replace your existing mesh with the coarsest mesh you can devise. 2. Resolve, and see if the problem persists. 3. If it does persist, try to replace the direct solver of all the variables, with a segregated solver of groups of variables. Note: you have not mentioned what you are solving. 4. If that persists, try to replace the direct solver with iterative solvers which use much less memory. You see the pattern ?
Posted: 8 years ago May 5, 2016, 1:01 p.m. EDT
Thanks for your reply. I have done 1 (by setting to the coarsest mesh), 2, and 4. How do I do 3? It's not in the manual PDF (cdn.comsol.com/documentation/5.1.0.180/IntroductionToCOMSOLMultiphysics.pdf). Also for 4, which should be the most followed the manual page 41 Steps 1 - 5, but to no avail as well. What is the next step now?
(In addition, I made the following changes in "Preferences >> Graphics and Plot Windows":
Rendering: OpenGL
Optimize for: Performance
Antialiasing: Off
Detail: Wireframe
... or should I return to "Factory Settings"?)
Thanks for your reply. I have done 1 (by setting to the coarsest mesh), 2, and 4. How do I do 3? It's not in the manual PDF (http://cdn.comsol.com/documentation/5.1.0.180/IntroductionToCOMSOLMultiphysics.pdf). Also for 4, which should be the most followed the manual page 41 Steps 1 - 5, but to no avail as well. What is the next step now? (In addition, I made the following changes in "Preferences >> Graphics and Plot Windows": Rendering: OpenGL Optimize for: Performance Antialiasing: Off Detail: Wireframe ... or should I return to "Factory Settings"?)
Posted: 8 years ago May 5, 2016, 2:22 p.m. EDT
search for segregated solver in the manuals. it is certainly there.
Also, perhaps if you provide your model, it will be quicker to see what is wrong with it
search for segregated solver in the manuals. it is certainly there. Also, perhaps if you provide your model, it will be quicker to see what is wrong with it
Posted: 8 years ago May 5, 2016, 4:26 p.m. EDT
Windows 10 Home Edition
Version 1511
OS Build 10586.218
Product ID: 00326-10000-00000-AA209
Processor : AMD A8-6410 APU with AMD Radeon R5 Graphics 2.00 GHz
Installed RAM 8.00 GB (6.93 GB usable)
System type: 64-bit operating system, x64-based processor
Windows 10 Home Edition Version 1511 OS Build 10586.218 Product ID: 00326-10000-00000-AA209 Processor : AMD A8-6410 APU with AMD Radeon R5 Graphics 2.00 GHz Installed RAM 8.00 GB (6.93 GB usable) System type: 64-bit operating system, x64-based processor
Posted: 8 years ago May 5, 2016, 4:32 p.m. EDT
I meant your COMSOL model. Still need that to help.
But since you did send your actual computer specs, I can tell you that part of the problem may be that you are solving a problem that is too large for the memory on your computer. an 8GB ram machine is very small for COMSOL to use; particularly for direct solver problems.
I could offer to solve your problem on my computer, and tell you how much memory it is using to solve.
I meant your COMSOL model. Still need that to help. But since you did send your actual computer specs, I can tell you that part of the problem may be that you are solving a problem that is too large for the memory on your computer. an 8GB ram machine is very small for COMSOL to use; particularly for direct solver problems. I could offer to solve your problem on my computer, and tell you how much memory it is using to solve.
Posted: 8 years ago May 5, 2016, 4:58 p.m. EDT
Can't find the model number for now, but the version number is 5.1.0.234 and the license number is 1013421.
I think the problem is slowly being fixed. After adding "Segregated", the program does not shut down after computing. But the following message shows up:
Failed to find a solution.
In Segregated Step:
Divergence of the linear iterations.
Returned solution is not converged.
Is something wrong with the "Segregated Step" settings? How can I fix this?
Can't find the model number for now, but the version number is 5.1.0.234 and the license number is 1013421. I think the problem is slowly being fixed. After adding "Segregated", the program does not shut down after computing. But the following message shows up: Failed to find a solution. In Segregated Step: Divergence of the linear iterations. Returned solution is not converged. Is something wrong with the "Segregated Step" settings? How can I fix this?
Posted: 8 years ago May 5, 2016, 5:47 p.m. EDT
I am talking about your COMSOL model file. The file you store and save when you are working on your model. That is what I need. Send it to me and I will take a look.
Posted: 8 years ago May 5, 2016, 8:25 p.m. EDT
Here is the file. Thank you.
Posted: 8 years ago May 6, 2016, 10:45 a.m. EDT
The model file you sent me is password protected.
Posted: 8 years ago May 6, 2016, 2:28 p.m. EDT
The password that you gave me "a." did not work. I guessed, and the password "a" did work fine. I question why you need a password, but that is not my business.
Your model runs fine on my machines. This is a linux shop, and I ran your model as is with v5.1 and v5.2. In a separate case, I removed your solver settings and started over with default solver settings. I also ran on a Windows-10 VM that I have v5.2 installed. All ran fine. I do not have a native Windows-10 v5.1, but I do not see any problems so there is no reason why your model should not run since Windows-10 is supported by COMSOL v5.1. Therefore, I suspect an install problem. Your model is set up with "extremely coarse" mesh, so I also tried "extremely fine" mesh and both ran fine. Here are some statistics:
X-coarse, 2828+151 dof, 899 MB ram, 9902 MB vram
X-fine, 317796+2576 dof, 2.73 GB ram, 11.76 GB vram
I am attaching files with the various changes I tried. I cannot attach the X-fine model since it is too large for this forum.
The password that you gave me "a." did not work. I guessed, and the password "a" did work fine. I question why you need a password, but that is not my business. Your model runs fine on my machines. This is a linux shop, and I ran your model as is with v5.1 and v5.2. In a separate case, I removed your solver settings and started over with default solver settings. I also ran on a Windows-10 VM that I have v5.2 installed. All ran fine. I do not have a native Windows-10 v5.1, but I do not see any problems so there is no reason why your model should not run since Windows-10 is supported by COMSOL v5.1. Therefore, I suspect an install problem. Your model is set up with "extremely coarse" mesh, so I also tried "extremely fine" mesh and both ran fine. Here are some statistics: X-coarse, 2828+151 dof, 899 MB ram, 9902 MB vram X-fine, 317796+2576 dof, 2.73 GB ram, 11.76 GB vram I am attaching files with the various changes I tried. I cannot attach the X-fine model since it is too large for this forum.
Posted: 8 years ago May 9, 2016, 12:23 a.m. EDT
Thank you for your help. I think I'll try to find other ways to reduce GB usage or to get the program running properly.
