mphinterp - Read data from model fails: Error in meshextend: GC overhead limit exceeded
I have encountered an error which I can not explain myself. I am calculating multiple models one after another with Matlab and read out data at specific coordinates.
This is part of my Matlab-Script:
dc_model; % Define Parameters, Geometry and Mesh, save model
for n = 1:204
...some stuff....
name = ['Homo-Model-',num2str(e1),'-',num2str(e2)];
solve_model; % Open meshed model, define physics, solve and save as name.mph
model = mphload(name); % load model
for m = 1:8
....some stuff...
mod_Vp(n,m)=mphinterp(model,'V','coord',[420;150;0]);
end
end
This worked fine up to n = 201. For n = 202 I get the following error:
Error using mphinterp
Java exception occurred:
Exception:
java.lang.RuntimeException: Error in meshextend: GC overhead limit exceeded
(rethrown as com.comsol.util.exceptions.FlException)
Old model cannot be reconstructed. Do Clear Solution to expunge
Error in run_model (line 76)
For some reason I cannot attach the model ("File size error"...)
I hope someone can help.
Sina
1 Reply Last Post May 26, 2016, 3:44 a.m. EDT
Posted: 9 years ago May 26, 2016, 3:44 a.m. EDT
We have had problems with memory leaks in the past. These are fixed now so the easiest way to solve your problems is to upgrade to the latest version of Comsol.
Without seeing your full script it is hard to give really solid advice, but try to see if you code works without this line:
A good advice that works for any version of Comsol is not to create an empty model and set up the whole model in a loop. It is much more efficient to set up the model once and to change the parts that need to be changed.
Lars Gregersen
Comsol Denmark
Hi We have had problems with memory leaks in the past. These are fixed now so the easiest way to solve your problems is to upgrade to the latest version of Comsol. Without seeing your full script it is hard to give really solid advice, but try to see if you code works without this line: model = mphload(name); % load model A good advice that works for any version of Comsol is not to create an empty model and set up the whole model in a loop. It is much more efficient to set up the model once and to change the parts that need to be changed. -- Lars Gregersen Comsol Denmark
