Heat Transfer to a laminar flow in a microchannel
Posted May 23, 2016, 7:41 a.m. EDT Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD), Microfluidics, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.4 3 Replies
I am currently simulating the heat transfer in a bent microchannel using the Conjugate Heat Transfer Physics. The simulation worked satisfactorily. Now I want to calculate heat transfer coefficients by means of the post-processing tools. To calculate the local heat transfer coefficient at a certain length of the cannel, I have to calculate the mean temperature of the fluid at that length in the first place.
A meaningfull definition of the mean temparature would be the surface integral of the temperature times the flux normal to the surface. I defined some cut planes as well as surface integrals (Derived Values) of T*(u*nx+v*ny+w*nz) to be evaluated on the respective cut plane. To get the mean temperature, one only has to devide this integral by the total volume flow of the inlet as all cut planes are defined in a way that the whole volume flow has to pass them.
In my example, the inlet temperature was 293.15 K and all walls were constant at 303.15 K. Unfortunately, the aforementioned evaluation of the mean temperatures gave totally useless values even below the inlet temperature. I attached a file which is a simplified version of the real problem showing the same problems. In this example, the inlet is 0.01 m/s and the cross section is 1mm*1mm so the integral has to be multiplied by 1e8 to receive the temperature. In my "real" problem, the cut planes are rather arbitrarily orientated in space.
I hope someone can help me. Maybe I just overlooked something.
Kind regards,
Alexander Rave from Hamburg, Germany
Kind regards,
3 Replies Last Post May 24, 2016, 7:09 a.m. EDT
