comsol server matlab, log file
I am running a comsol *.m file in a Matlab window.
I would like to know how to create a log file in order to see the time solver progress .
Francois
8 Replies Last Post Feb 7, 2014, 12:53 p.m. EST
Hello Francois Guinot
Posted: 1 decade ago Feb 8, 2011, 9:01 a.m. EST
Any solution ?
Any solution ?
Posted: 1 decade ago Feb 11, 2011, 3:51 a.m. EST
Thanks to the Support, I have solved my problem. In V4.1, writing :
ModelUtil.showProgress(true);
displays an independent window with a progress bar and the log.
Thanks to the Support, I have solved my problem. In V4.1, writing : ModelUtil.showProgress(true); displays an independent window with a progress bar and the log.
Posted: 1 decade ago Feb 11, 2011, 7:02 a.m. EST
thanks for the update, was'nt avare of that one ;)
Hi thanks for the update, was'nt avare of that one ;) -- Good luck Ivar
Posted: 1 decade ago Feb 11, 2011, 11:00 a.m. EST
how to connect matlabR2010a to comsol v 4.1?
pls help.
Regards!!
deepak
how to connect matlabR2010a to comsol v 4.1? pls help. Regards!! deepak
Posted: 1 decade ago Feb 11, 2011, 11:09 a.m. EST
During Comsol installation, verify if livelink for matlab will be installed and then specify the Matlab set-up directory.
When the installation is done, you can run comsol with matlab.
On windows systems, just double click on "comsol 4.1 with matlab" in your programs menu.
On linux, if i remember the command line is :
comsol matlab
During Comsol installation, verify if livelink for matlab will be installed and then specify the Matlab set-up directory. When the installation is done, you can run comsol with matlab. On windows systems, just double click on "comsol 4.1 with matlab" in your programs menu. On linux, if i remember the command line is : comsol matlab
comsol matlab
Posted: 1 decade ago Feb 11, 2011, 11:10 a.m. EST
Check the KB for matlab, and the COMSOL installatin doc, there are several articles on the Forum too
Hi Check the KB for matlab, and the COMSOL installatin doc, there are several articles on the Forum too -- Good luck Ivar
Posted: 1 decade ago Feb 7, 2014, 12:53 p.m. EST
For future reference, if you use the command below:
ModelUtil.showProgress('filename');
the progress will output to 'filename'. This is particularly useful for Mac OS X because the progress bar is not supported.
For future reference, if you use the command below: ModelUtil.showProgress('filename'); the progress will output to 'filename'. This is particularly useful for Mac OS X because the progress bar is not supported.
