9 years ago
Jun 14, 2016, 9:59 a.m. EDT
I would say AC/DC->Magnetic fields (mf)
When you start building a new model with the Wizard you have a little description of each physics that you want to choose that appears on the right side and explains a bit what it is good for....
Or if you want more info you can press F1 for help
Usually, for magnetic forces, you can use mf (if electric field contributions are negligible) or mef ((if electric field contributions are not negligible)
Also, the magnetic force values are not always correct and getting them right is a bit tricky. You have to have a fine mesh, avoid sharp corners, and use infinite element domains around your model....
A simple check I always do is to see if the force and the reaction force are equal and in the opposite directions :-)
If this is the first time you use the magnetic module start with an example from the application library.
Example:
www.comsol.com/model/permanent-magnet-78
I Hope this helps
Dara
Example: https://www.comsol.com/model/permanent-magnet-78
I Hope this helps
Dara
