Sound after simulation finished
Hi there
I have 2 studies to run (1 steady state en 1 time-dependent), I first run the steady-state and afterwards the time-dependent.
Is there a way to create a sound in COMSOL when the simulation of my first study has been finished ?
Thanks in advance,
Louis
1 Reply Last Post Jul 21, 2016, 11:49 a.m. EDT
Posted: 9 years ago Jul 21, 2016, 11:49 a.m. EDT
I assume that you want to make some adjustments or check results from the first study before running the second. If not, you can either use two study steps within the same study, or add a Study Reference to collect the two studies together.
But if you really want to play a sound, you can wrap your model in an app using the Application Builder. There it is easy to make it play any tune (there are three predefined sound files, intended for exactly this purpose).
Henrik
Hi, I assume that you want to make some adjustments or check results from the first study before running the second. If not, you can either use two study steps within the same study, or add a Study Reference to collect the two studies together. But if you really want to play a sound, you can wrap your model in an app using the Application Builder. There it is easy to make it play any tune (there are three predefined sound files, intended for exactly this purpose). Regards, Henrik
