how to integrate a heat source, problem with units
hey,
my name is jaques.
i try to solve a problem including little heating modules. these modules have a heat output of 25W each and their dimensions are 2.7 x 1.5 x 1.5 cm.
my questions are:
is this a general or a linear source in that case and how do i convert these 25W into W/m³ or W/m³*K.
thanks for your help, even if this perhaps seems to be a total beginners question.
yours truly
jaques
3 Replies Last Post Dec 17, 2010, 10:45 a.m. EST
Posted: 1 decade ago Dec 16, 2010, 5:06 a.m. EST
if you have a heat source of 25[W] for a given volume, the average heat density you should apply is for a 3D domain
Q[W/m^3] = 25[W]/(your_ domain_volume[m^3])
the your_domain_volume is obtained by a integration variable (or volume operator in V4) of "1" as integrand.
What you must catch with COMSOL is that the values you enter in the GUI fields are defined "per FEM element" of size dV=dx*dy*dz (in Cartesian) so you enter body forces in [N/m^3] and heat in [W/m^3] etc with the assumption that you integrate over the applicable domains.
for 2D nothing changes, but COMSOL assumes its working in 3D with a depth of ".d" or ".thickness" (by default = 1[m] for most physics) so then you must multiply you integrand (on a surface by 1*solid.d for a ST case.
In 2D-axi it is the "loop length" that matters which is "2*pi*r"
Hi if you have a heat source of 25[W] for a given volume, the average heat density you should apply is for a 3D domain Q[W/m^3] = 25[W]/(your_ domain_volume[m^3]) the your_domain_volume is obtained by a integration variable (or volume operator in V4) of "1" as integrand. What you must catch with COMSOL is that the values you enter in the GUI fields are defined "per FEM element" of size dV=dx*dy*dz (in Cartesian) so you enter body forces in [N/m^3] and heat in [W/m^3] etc with the assumption that you integrate over the applicable domains. for 2D nothing changes, but COMSOL assumes its working in 3D with a depth of ".d" or ".thickness" (by default = 1[m] for most physics) so then you must multiply you integrand (on a surface by 1*solid.d for a ST case. In 2D-axi it is the "loop length" that matters which is "2*pi*r" -- Good luck Ivar
Posted: 1 decade ago Dec 17, 2010, 7:42 a.m. EST
hey ivar,
thanks for you quick reply. theoretically i understand what you told me, but i have a problem in v4 to find the volume operator you mentioned, because i'm new at v4
thanks for your help and have a nice weekend!
jaques
hey ivar, thanks for you quick reply. theoretically i understand what you told me, but i have a problem in v4 to find the volume operator you mentioned, because i'm new at v4 thanks for your help and have a nice weekend! jaques
Posted: 1 decade ago Dec 17, 2010, 10:45 a.m. EST
the coupling variables are in v4 defined as "Definitions Model Couplings Iintegration" on a domain
Hi the coupling variables are in v4 defined as "Definitions Model Couplings Iintegration" on a domain -- Good luck Ivar
