Dec 16, 2010, 10:56 a.m. EST
Since the only specific issue you have mentioned is the handling of varying thickness, I will give my two cents about that.
I don't know if you are defining the dust layer as a property of the plate, or if you are modeling the layer as a separate domain using the geometry. If the former, you can use an expression (which can be a function of the position along the axes) instead of just a number. If the latter, you can simply make the domain representing the dust layer to have an uneven shape.
I hope this helps.
Aytug
I hope this helps.
Aytug
Dec 16, 2010, 1:48 p.m. EST
actually i am stucked into the step if how to make the geometry of my problem
i have to make a kind of geometry where i can use a time varrying volatge and then apply that voltage across a wire that is above a plane which is grounded and then i have to observe the variation in electric field across wire.what kind of shape you suggest
thank you
i have made this account with my actual name jhanzeb.
now only i myself can acess this account.and i also change my phone number and now i have given my personal number and email id.thankyou
thank you
thank you
thank you
Dec 16, 2010, 1:56 p.m. EST
there is an ACDC webinar in 10 min (2PM ET 20hGMT+1) see the main COMSOL EVENTS - Webinar. YOu might get some good tips by following the presentation
Dec 17, 2010, 11:21 a.m. EST
The ACDC Archive of the webinar along with many others can be found on the Webinars page here:
www.comsol.com/events/webinars/
Web Program Manager
http://www.comsol.com/events/webinars/
[QUOTE]
[/QUOTE]
Web Program Manager
