Modeling Electromagnet
attached is a model of an electromagnet (DC). The excitation happens at the coil endings via "Electric potential" and "Ground".
I managed to solve that model in v4.0a with the direct solver PARDISO with a finer mesh and linear elements. Unfortunately, this method consumes a huge amount of RAM and it is only a submodel for further investigations for me. Now I want to solve that with the iterative solver (coarser mesh but quadratic elements).
When I set a constant damping factor (see solver 1) I get "Divergence of the linear iterations". Depending on what value I set for the factor, this error occurs earlier or later.
When I set automatic damping factor (see solver 2), the solution process stops after 1 iteration without error, but the stepsize is still very large and I don't believe it is converged. Moreover, the solution process always starts with damping factor 1 although I set a smaller value.
What do you think, is this a kind of bug in COMSOL or is there something wrong with the boundaries (they changed from v4.0a to v4.1 in AC/DC module)? What can I do solve that model. I already tested various mesh sizes and solver settings.
Any comment would be appreciated.
mb
2 Replies Last Post Dec 17, 2010, 8:38 a.m. EST
Posted: 1 decade ago Dec 17, 2010, 7:25 a.m. EST
Hello Marcel,
i hope i can help
I think your problem is the small conductivity in the air gap. Try a bigger value sigma= 1e-3 then should work your constant damping solver.
For a better result make a new simulation with sigma = 1e-9 and use your last result as start conditions.
Then you can compare your result with automatic solver damping.
kind regards
Matthias
Hello Marcel, i hope i can help I think your problem is the small conductivity in the air gap. Try a bigger value sigma= 1e-3 then should work your constant damping solver. For a better result make a new simulation with sigma = 1e-9 and use your last result as start conditions. Then you can compare your result with automatic solver damping. kind regards Matthias
Posted: 1 decade ago Dec 17, 2010, 8:38 a.m. EST
Hello Matthias,
thanks for your hint. Indeed convergence seem to improve with constant damping factor.
With damping factor set to automatic, it still stops after 1 iteration.
Thanks so far,
Marcel
Hello Matthias, thanks for your hint. Indeed convergence seem to improve with constant damping factor. With damping factor set to automatic, it still stops after 1 iteration. Thanks so far, Marcel
