cannot be convergenced or division by zero
Hi guys,
Now I am using COMSOL 5.0 to calculate mantle velocity field and thermal structure beneath mid-ocean ridge combining creeping flow node and convection-diffusion equation.
In my model, the viscosity is related to the temperature and spatial gradient of the velocity.
I first calculated the mantle flow and temperature for a constant viscosity. Then I use the strain rate and temperature from the initial solution to calculate viscosity values and solve the combined equations described above. Then I iteratively increased the maximum viscosity from 1e19 to 1e23.
While the solution cannot be converged at a viscosity value higher than 1e22.
The problem is 'division by zero'.
I changed the direct solver to iterative solver, and use constant Newton nonlinear method, the solution cannot be converged. If I use automatic Newton nonlinear method, the solution can be converged, but the results is wrong.
Could you give me some suggestions to solve the problem?
Many thanks,
John
0 Replies Last Post Aug 26, 2016, 6:41 p.m. EDT
Hello John Zhang
