Hollow cylindrical optical cavity
Posted Dec 20, 2010, 10:41 p.m. EST RF & Microwave Engineering, Wave Optics Version 4.0a 15 Replies
I'm fairly new to COMSOL, I was trying to model the optical modes in a hollow silica cylinder - which is easy enough to do with PEC boundaries, but I was hoping to see the modes in the presence of a surrounding air atmosphere. I was hoping there was a simple way to set up the equivalent of an infinite air domain surrounding it. Setting up a small air boundary around the cylinder causes problems because there's modes within the air cavity, setting up a very large domain causes problems with meshing and solving time.
Advice greatly appreciated.
-I tried to attach the file but I was given a file size error
first of all to attach files, clear them from the solution eventually also the mesh (no problem in v.4) and do a reset model, then you should have no difficulties to upload it. OK we wouldneed to resolve it cannot have everything ;)
in RF you have the PML isnt that enough (V4.1 at least) ?
I'm using v.4, when I try defining the air domain as a PML I either get an undefined value error or if it compiles I just get an imaginary solution
help appreciated
butI do not see any electric field defined anywhere. With E=0 you will not solve much apart enhance some numerical noise, no ?
then I'm not suree how to interpreste those modes (once you select some E scatter field BC as the defined "air" cylinder modes and the glass defined modes will certainly interact.
You could use some periodic or symmetry boundaries perhaps, and some PML/infinite elements too, no ?
I'm a little confused, right now I have the electric field defined under the physics node by the refractive index
Is there some other way to define it? Do you mean define a initial value?
And you're suggesting setting the air domain BC as a scattering boundary?
I can try that, thanks
kee s.
I get E=0 when solving so I see no electric field in there, I added a scatter boundary field with Ez or Ex=1[V/m] on the lower circular boundary and then I see some modes build up
I was able to find the modes I was interested in by putting a scatter boundary around the air cylinder and making a plane wave
I had a weird issue though - I saved the model that worked and when I came back later and ran i again I got a different result and the error message
UMPS allocation factor increased to 1.44.
The relative error is greater than the relative tolerance.
Relative residual 1.5e-014
Relative error 0.0016
Relative residual 4.3e-014
Relative error 0.0019
Relative residual 1.4e-013
Relative error 0.00077
Relative residual 1.2e-014
Relative error 0.0011
Relative residual 2.2e-014
Relative error 0.0031
Relative residual 2.4e-014
Relative error 0.0014
Relative residual 3.8e-014
Relative error 0.0017
Relative residual 9.9e-015
Relative error 0.0021
Relative residual 1.7e-014
Relative error 0.0035
Relative residual 2e-014
any idea what this is?
thanks again for your help so far
funny, have you tried to save and restart COMSOl ? and which version 4.0 or 4.1 ? similar things did happen for me in v4.0 and "a", hardly with the new version
I was able to get modes by adding a scattering boundary conditions and an incident plane wave, like I said earlier and I got modes like shown in the image
But I can no longer get the same modes by running the same file, but I cant tell what/if anything's changed
I suspect that is realted to your (original) model build-up and the mesh density, your glass tube is hanging in free space with an air region that is also a cavity (no PML's) and you are looking at very high order modes so I wounder if these are not coupling almost randomly.
Then I do not understand the new model buildup: where is the PML and why remove the air in the middle ?
are you modelling an infintely long glass tube or just a limited one ?, in the first case you can use periodic boundaries to make it "infinite long"
then to remove the "orange" unit issues in your field equation use rather
cos(y[1/um]*pi/1.55)
or
cos( (y*pi/(1.55[um]))[1/m] )
One more thing, are you sure you have a fine enough mesh ? to resolve your wavelength corectly you need at least 7-10 elements per wavelength (also in the glass)
The file I posted has a finite glass cylinder (what I want) and a surrounding air domain outside and inside that's defined as a PML, with a scattering boundary condition on the outside with an incident planewave
I feel like I should be able to get modes with these conditions, and at least in one instance of running the model I did. I'm not sure why it won't find modes now or what's changed from before
In your last file I didnt fnd the air "inside", check your domains, then I would have had some air outside before the plm, and I'm not sure to understand your two reflecting surfaces at the end if the cylinder, do you want to have a cavity or ?
Also have at least 7-10 elements per wavelength, otherwise your field is not resolved corretly you are "oversampling"
I've tried setting the top and bottom of the air cavity to the scattering boundary condition but it hasn't yielded anything
I thought defining a hollow cylinder inside a larger air cylinder would leave an air domain in the center of the hollow portion, maybe I was wrong? Regardless since I'm defining the waves by epsilon and k, and I have air with epsilon = 1 and k = 0 it should give me the same results with vacuum in the center anyway
www.megaupload.com/?d=0JXYGUVU
This was a model I ran a couple days ago with the results not cleared, it yielded the sort of results I'm looking/hoping for, but like I said earlier I can't get the same results when running the same model
I've tried increasing the fineness of the mesh as much as possible and still haven't had any better luck
thanks again for all your help so far
It's on this megaupload file with the solutions I found left saved (too big to attach)
www.megaupload.com/?d=IJGO3PHY
If any one has any ideas why I can only sometimes get these solutions, or suggestions as to how else to model it, I'd really appreciate it
Attached is my most recent attempt it's a hollow cylindrical silica shell with an air domain outside and inside, with a pml on the external air domain and scattered external boundary condition - but I still can't solve for any modes
help appreciated
Does anyone have any experience modeling 3D photonic cavities without mirrored BCs (i.e., surrounded by air) that could give me some pointers?
Suggested Content
- BLOG Magnetic Shells Designed to Improve Energy Transfer
- BLOG Detecting Dark Matter Axions with a Microwave Cavity
- BLOG Study Contaminant Removal in Membrane Dialysis Devices with an App
- BLOG Efficiently Optimizing Solar Dish Receiver Designs
- BLOG How to Use Dispersion Curves to Analyze Fluid-Filled Pipes
