Inconsistent Units
Posted Dec 21, 2010, 6:58 p.m. EST Parameters, Variables, & Functions Version 4.2 8 Replies
I´m trying to incorporate the following expression on Subdomain expressions:
D=0.926*T^2.5/(T*245)
the result should be in mm^2/s, but It shows me "Inconsistent Units"
even when I try the following expression:
T^2.5/T^2.5
It stills to show the same message (inconsistent units)
Best Regards,
Orlando
the units in comsol has problems with non-integer powers, in the last versio I belive ^0.5 is accepted so try to rewrite your formula as:
D=0.926*T^2*sqrt(T)/(T*245)
In 3.5a this trick should not work as non-integere powers are not treated correctly for the units.
In any case if you do not put any other units your results is in K^1.5 and not mm^2/s
I am facing the same problem with non-integer units. Can you please tell how you were able to work out with this.
Thanks.
Aseem
Units errors in orange are only warnings, so they do not block your clculations.
With fractional power, the easiest is to remove the units from the power expression by a [1/over_the_units], and set them back on the final results with an approprate [new_units]
Please help me to understand about my issue with Units:
I get an Inconsistent Units warning (in orange colour) when I input an expression into my equation : u=BOD*theta^(T-20)
with units are defined: u [mg/L]; BOD [mg/L]; theta [1/s]; and T [K].
Do I input correctly (about UNITS) the expression into Comsol , please show me to know?
Best regards.
try a (T-20[K]) as the "20" is without units and T is probably flagged as [K], as you suggest
Thank you for your help, but I have tried with your trick, the warning is still happening.
I will try another way to check where in the expression makes this error, and let you know if I find out a solution
now I see that you have a power "^" in there I'm not sure you should have units on a power indice, that should be unitless, (I first read wrongly * and not ^ ;)
A good way to make COMSOL Multiphysics interpret T in Celsius degree, and disappear Inconsistent Units warning, is that:
u=BOD*((theta^(T-20))
with units are defined: u [mg/L]; BOD [mg/L]; theta [1/s]; and T [degC/K] with T value is input in Celsius (in Parameters Table).
But I find out another strange situation, that is when I input
u=BOD*(theta^(T-20)) with T is defined in [degC/K] or T [degC] --> get Unit Syntax Error, even I check it seems correct in math, and Comsol still calculate ok.
u=BOD*((theta^(T-20)) or: u=BOD*((theta^(T-20) with T is defined in [degC/K] or T [degC] --> no more warning, even the expression misses one close bracket ")", and when Comsol start to compute, it finds out the error.
u=BOD*(theta[s]^(T[1/degC]-20)) with T is defined in [degC] in Parameters Table, disappear the warning but when Comsol start to compute, it finds out the error.
Why is that? Please help me.
Best regards.
Suggested Content
- KNOWLEDGE BASE Solving time dependent models with inconsistent initial values
- KNOWLEDGE BASE Improving Convergence of Transient Models
- BLOG Understanding Stabilization Methods
- BLOG What Happens If I Use 2 Different Unit Systems in 1 Simulation?
- FORUM Error entitled "the DAE is structurally inconsistent"
