Oscillating flow problem
I have inlet oscillating velocity boundary condition of 20*sin(3.2892*t) at inlet and exit boundary condtion as 1 atm. pressure for a simple 3D cylindrical geometry.When I tried to solve this problem it is displaying the error 'Failed to obtain consistent initial values'.The I tried to obtain the initial values by going to the option 'Solver parametes-time stepping-time steps taken by solver-INITIALIZATION ONLY' settings.Then I ran the problem,still its showing the same error message. ie, while trying to find the consistent initial values itself it is displaying the same error.Can anyone help me in this regard...
with thanks,
S.M.Ananth
1 Reply Last Post Dec 22, 2010, 6:05 a.m. EST
Posted: 1 decade ago Dec 22, 2010, 6:05 a.m. EST
outlet at 1 atm? what about your initial pressure at your subdomain? should be 1 atm , too. At least, set your pressure to zero (only pressure differencen should be taken into consideration) and, if necessary, adjust your total pressure used in your material properties.
If it is cylindrical, why you don't try 2D-axialsymmetric mode? Saves you A LOT of computational time ...
Another few remarks: 20m/s could be a tubulent flow. you are setting the velocity on the whole inlet to this sin(t...) ? This could trouble with the "wall"-condition which you set up to your wall. -> try to adjust your inlet-velocity-profil to have a zero velocity at your wall-inlet-corner (which should be smooth, of course ;) ). And ... the mesh is important :)
merry christmas!
btw CFD is not really easy ..
outlet at 1 atm? what about your initial pressure at your subdomain? should be 1 atm , too. At least, set your pressure to zero (only pressure differencen should be taken into consideration) and, if necessary, adjust your total pressure used in your material properties. If it is cylindrical, why you don't try 2D-axialsymmetric mode? Saves you A LOT of computational time ... Another few remarks: 20m/s could be a tubulent flow. you are setting the velocity on the whole inlet to this sin(t...) ? This could trouble with the "wall"-condition which you set up to your wall. -> try to adjust your inlet-velocity-profil to have a zero velocity at your wall-inlet-corner (which should be smooth, of course ;) ). And ... the mesh is important :) merry christmas! btw CFD is not really easy ..
