failed to evaluate variable while simulating cantilever
hi all
I am trying to simulate the cantilever without any symmetry condition as i would like to later modify the structure by adding a few more elements.I am getting the following error
anyone knows why this is happening.
Exception:
com.femlab.jni.FlNativeException: Failed to evaluate expression
- Expression: V
Failed to evaluate variable
- Variable: V
- Geometry: 1
- Boundary: 10
Undefined post expression
X plot failed.#Boundary
Stack trace:
at evaltree.cpp, row 866, ()
at xevalutil.cpp, row 2612, ()
at xmodel_post.cpp, row 810, ()
at com.femlab.xmesh.Xmesh.postEval(Native Method)
at com.femlab.xmesh.Xmesh.postEval(Unknown Source)
at com.femlab.post.PostServer.a(Unknown Source)
at com.femlab.post.PostPlot.elemPlot(Unknown Source)
at com.femlab.post.PlotCmdData.a(Unknown Source)
at com.femlab.commands.PlotCommand.evalOnServer(Unknown Source)
at com.femlab.commands.FlCommand.runServerCode(Unknown Source)
at com.femlab.server.ServerProxy.eval(Unknown Source)
at com.femlab.commands.FlCommand.a(Unknown Source)
at com.femlab.commands.FlCommand.eval(Unknown Source)
at com.femlab.commands.a.a(Unknown Source)
at com.femlab.post.PlotType.a(Unknown Source)
at com.femlab.post.PostModelMph.a(Unknown Source)
at com.femlab.view.c.a(Unknown Source)
at com.femlab.gui.PostMode.a(Unknown Source)
at com.femlab.gui.GuiMode.j(Unknown Source)
at com.femlab.gui.au.a(Unknown Source)
at com.femlab.gui.au.b(Unknown Source)
at com.femlab.api.client.w.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at com.femlab.gui.e.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.Dialog$1.run(Unknown Source)
at java.awt.Dialog$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Dialog.show(Unknown Source)
at com.femlab.controls.FlDialog.showAsDialog(Unknown Source)
at com.femlab.controls.FlDialog.show(Unknown Source)
at com.femlab.controls.FlModalDialog.show(Unknown Source)
at com.femlab.gui.dialogs.z.run(Unknown Source)
at com.femlab.util.x.run(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
1 Reply Last Post Dec 31, 2010, 10:35 a.m. EST
Posted: 1 decade ago Dec 31, 2010, 10:35 a.m. EST
looks like your variable V (normally the voltage in COMSOL) is not defined correctly or there are some missing BC's
Hi looks like your variable V (normally the voltage in COMSOL) is not defined correctly or there are some missing BC's -- Good luck Ivar
