Jan 1, 2011, 6:11 a.m. EST
HI
happy new year
I assume you are rather right for point 1)
for 2) it could come from v4.0a ? the solver settings are not optimal in the first version of v4, it's better in 4.1, from my experience it's either from a scaling issue or a mesh density issue
HI
happy new year
Jan 1, 2011, 6:23 a.m. EST
Thank you very much =)
i change version and its work! very good, thank you for good advise)
Excuse me, can you help me one more question?
what boundary conditions must i set if i get simple pipe with pressure at the entrance 1 MPa and at the exit the pressure will be 1MPa - pressure losses ? But pressure losses depends of temperature, velocity and so on.....
may be there is some better idea?
Jan 1, 2011, 6:37 a.m. EST
I'm not the best on CFD, and spcially I'm still fighting with the issue of "absolute" and "gauge" pressure in COMSOL, so each time I make me up a simple case, check analytically and then validate.
If you have a pressure driven fow, you need the absolute pressure at the "inlet", then if the exit is free 1[atm] is for me a normal absolute pressure, just check carefully how your COMSOL physics is setting up the equation (check the doc in 4.1 it's much more complete than it was in v4.0) and try out a few simple cases
Jan 1, 2011, 6:42 a.m. EST
Thank you very much )
yes , there is something strange with pressure.
Your solutions help me, thank a lot =)
Jan 1, 2011, 9:36 a.m. EST
It's not strange, it's reproducible and a matter of normalisation, but not the one that seems the most logic for me, I need to find some time (what I never have, I'm always too busy) to study more CFD ;)
