Jan 2, 2011, 3:00 a.m. EST
have you tried to use a step function (Heaviside derivative step) to ramp up quickly your pressue value ?
Jan 2, 2011, 1:52 p.m. EST
Thanks, Ivar. I gave that some thought by changing my initial step from stationary to time-dependent, but then I have to deal with some way to figure out which time-dependent step I'm in in order to determine whether to use a constant or the function.
What I really would like to do is use is define my inlet based on:
func( t[1/s] )
The COMSOL documentation says that for stationary problems, t is defined as 0, which is what I want, However when I try to use this approach, I get a message "Failed to evaluate variable" for t, indicating it is undefined.
Any other thoughts?
Steve
func( t[1/s] )
Any other thoughts?
Steve
Jan 2, 2011, 2:16 p.m. EST
I have noticed that, depending on version/patch too the behaviour with the internal variabloes such as "t" and "lambda" changes somewhat.
Often I define a parameter such as t=0, if accepted it solves the issue. But then when adding a transient solver often you get back the error message.
Another way, is to add a dummy (unused but declared) transient solver study case, this defines t=0 for you.
Now the heaviside (or v4 "step" function, already defined in v4) is typically used in transient, but you can also, for stationary use it to ramp with a local "Param" parameter
Jan 4, 2011, 1:21 a.m. EST
Ivar, with a little help from COMSOL support I was able to solve the problem. By defining the variable t as a global parameter with a value of 0, it was picked up and used by the stationary solver. The time-dependent solver then reused t for its own purposes.
Steve
Steve
