Maximum and minimum
I am using the parameter sweep study to optimize my system. In my case I am trying to maximize the acoustic pressure by changing geometries. I can see the results (maximum and minimum) for a single parameter value, but I need to see the maximum across all tested values. Is it possible to find the maximum across all parameter values, or at least export the parameter values? I have far too many values to practically look at each one individually.
1 Reply Last Post Oct 5, 2016, 5:30 p.m. EDT
Posted: 8 years ago Oct 5, 2016, 5:30 p.m. EDT
To find maximum of dependent variable in model for each value of a parameter, you can use
Results > Derived Values > Maximum
For 3D model, choose Volume Maximum (over all domains)
When you evaluate the derived value, you will get table of values, one row for each value of the parameter. (I am assuming you have done a study with one parameter as in
Study Extensions > Auxiliary sweep > (your parameter) )
-DW
Hello, To find maximum of dependent variable in model for each value of a parameter, you can use Results > Derived Values > Maximum For 3D model, choose Volume Maximum (over all domains) When you evaluate the derived value, you will get table of values, one row for each value of the parameter. (I am assuming you have done a study with one parameter as in Study Extensions > Auxiliary sweep > (your parameter) ) -DW
